Red light flashes 6 times ?
I have a 2006 philips ambilight 37" that just rescently has started to act up after owning it for 3 years. My problem is that i have a red light blinking 6 times and when i try to turn the unit on, the green light will go on and then theres a click and back to red (flashing 6-times) Now, i am no electrician but, to me that says that there is a chance that there is some sort of code with the flash? Can i be on the right track or is there someone out there that can give me some advice?------Oh, the tv fails to power up also. Please, help if you have any helpful information or advice
  • nrahman Dec 29, 2008
    i have the same problem with the flashing 6 times after it switches off,if any1 knows the solution or the problem(why it flashes 6 times)let me know thanx
SOURCE: Philips Ambilight
The correct remote has an ambilight button to toggle ambilight on and off
Posted on May 28, 2008
Slinteriors
  • 8617 Answers
most likely its the audio amplifier board where your having the problems
Posted on Jun 06, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips ambilight 42inch plasma
You can fix this yourself with a software upgrade - get the upgrade from Philips website - go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software". Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Posted on Jun 09, 2008
SOURCE: i have a philips 42pf9641d/10 and the ambilight on
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Posted on Jul 30, 2009
stonephoenix
  • 563 Answers
SOURCE: i have a 50'' philips tv flashing an error code
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher. You should call the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
Philips plasma with Ambilight...turned on today, no picture. Red light flashes 6 times in succession over and over. The unit is 10 years old .... Repair or replace ?
Could be a power supply fault.
How deep is your pocket will answer whether to replace it assuming there is a repair shop that can repair it at a cheaper price.
Jan 23, 2017 | Philips Televison & Video
Philips 42pf9631d/37 6 slow red flashes and 3 fast
6-7 blinks means there is an issue with the power supply...
I found a replacement for my 42pf9631d/37
Part # Lj44-00117A
at TSM Inc. for $110.95 with free shipping...
http://www.tristatemodule.com/p-10120-lj44-00117a-samsung-tv-module-power-supply.aspx
Jan 28, 2010 | Philips 42PF9631D 42 in. Plasma Television
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Philips ambilight 42inch plasma
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
LCD Screen - All the black is green
go to the philips web sight and download the latest firmware upgrade unzip and store to USB flash stick and follow the instructions on installaition.
Apr 17, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Aug 31, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
