Question about Pioneer Audio Players & Recorders
Blown subwoofer I bought two 12" pioneer premier shallow subwoofers and only had them going for about two weeks when one of them blew. I only had them running at around 300 watts and there suppose to be able to withstand 1400. Then I bought another to replace that one and after I received the new one the other old subwoofer blew and this shouldnt happen. How can I fix this or should I start using a different kind of subwoofer?
  • soup_moto_21 Dec 27, 2008
    I am using a 1000 watt sony xplod amp and only have it turned up about half way. Im not sure how big the box is it is made for shallows and I bought it at video kingdom i believe
  • 15,935 Answers
1400 is PEAK power. not to be mistaken with RMS. 1400W in SHORT bursts.
RMS on them is 500-600W.
Your amplifier gain may be improperly set. How big is the enclosure and what amplifier are you using. All of these things will play a factor in answering your question. Dont expect a $400 experience from $100 subs.
Posted on Dec 26, 2008
Speaker blown?
disconnect the amp and do a "pop" test with a 9v battery, it should be clear and no rattle... if it rattles sub is blown
Jan 29, 2014 | Kicker Comp CVT 12 Car Subwoofer
Subs are smoking
You have officiqlly burned them out by creating a short insid of them
Feb 26, 2013 | Pioneer Premier TSW-3002D4 12 Inch...
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
Premier sub used to work great ... now nothing
Did you check to make sure that you didn't blow a channel in the amp? Another thing to check would be the connection on the inside of your box, maybe there is just a wire loose.
Dec 19, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Blown sub?
yeah if its poppin its blown. sorry dude. good luck.
Oct 22, 2008 | Jl Audio 12W3 Car Subwoofer
Wiring speakers to amp.
Hi mate you need to leave a bit more detail on the amp so I can help, what are the outputs saying?
Feb 18, 2008 | Pioneer TS-W125C Car Subwoofer
Amps
It comes down to Amperage and RMS, your best bet is to go in and talk to a salesman at a stereo shop. That way he can decide on what sort of power you want and how you wanna use the subs. But 1000amp AMP is probably a good start 4 channel of course. Alpine or SOny make some kick a$$ AMPS
Feb 17, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
62 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
