Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
When i hookup dvd 2 dvi i get pic but no sound
I have a ViewSonic N2750W
DVI does not include audio as HDMI does so you have to get a 3.5mm mini to dual RCA plugs, available on ebay, I just bought one for $2.99 plug the output from your reciever to the green mini socket labeled PC AUDIO
Posted on Feb 16, 2012
  • Tony Perkin Feb 16, 2012
I think I know what the problem is. I have the same tv and been going through the same thing. Looking in the manual it says you need to get sound through the pc audio its the green audio jack. you have to get a female Y analog to pc cable. I saw one on ebay for $2. My problem is I've also got my computer hooked up.
Posted on Dec 30, 2008
I do not have my remote for my viewsonic N2750w. And i cannot find a universal remote that works. Can you tell me one that will work?
You could order a substitute remote ( as original is not available any longer ) from :-
http://remotes.com/store/viewsonic/n2750w.html
If you want to buy universal remote, be advised that for Viewsonic it would not be too successful and moreover, the one which is compatible ( Harmony ) would be expensive.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 10, 2011 | ViewSonic N2750w 27 in. HD-Ready LCD...
Audio OK no video
Ur LCD inverter board is dead.Replaced this inverter board will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long shape board.
Apr 21, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
When turned on, it make a ripple sound
The class D sound amp circuits are bad, it is part of the main board, very expensive, this is a common problem with this model, I fixed two of them, usually after 30 minutes it will soud like motor boat.
http://www.shopjimmy.com/main-unit-jc278a61u-from-viewsonic-n2750w-2.htm
Dec 09, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
No video but sound works fine
how old isw this set, get a flash light and point it at the screen look very carefully and see if you can see a pic if so then open it up you have a small pico fuse going to your lcd screen replace and that should fix it good luck
Sep 24, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
SCREEN SAYS OUT OF RANGE
I assume that you are using a DVI to VGA connection since this TV dose not have a DVI connection.
Make sure that the resolution are set to the following supported resolution:
1280 x 1024 @ 60 Hz
1024 x 768 @ 60, 75 Hz
800 x 600 @ 60, 75 Hz
640 x 480 @ 60, 75 Hz
Or just make sure its set to 1366x768 @ 60Hz
May 13, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Owners Manual
Go to ViewSonic at:
http://www.viewsonic.com/support/userguides.cfm
Enter your serial number or "n2750w".
Provides PDF document.
Save to your computer by clicking the "disc" icon at the top left of the Adober Reader screen.
Mar 31, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Problem with picture
Most likely it's the LCD panel assembly failure. Either the inverter board or scaler board.
Jan 18, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Viewsonic 3252W 32"
buy another tv. All parts no longer available. and all the board can't be rebuild. Gabage.
Oct 24, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
HDMI
Use the input button on your remote control... as you press input you should see VID 1, VID2, COMP 1, FRNT and then DVI... When you get to DVI you should see your picture..
Oct 15, 2007 | RCA P52926 52" Rear Projection Television
Greenish tint
First of all component inputs are analog as the only digital inputs are the DVI or HDMI inputs on a TV. You might have color adjutments in the menus somewhere that allow you to compensate for color weakness on one or more colors. If not you most likely have a bad digital board.
Apr 07, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
196 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
