Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Got full bar wireless signal...........
But cannot connect to the internet on the base unit and thus the wireless unit... Any ideas ??
    Sergeant:
  • 366 Answers
Connet to your router using a LAN cable.
Be sure you can browse
Configure your Wlan with same protocol WPA/WEP) and Keys (TKIP)
or remove every protection from your Wlan (not recommanded)
Do you see your SSID in your PC?
Posted on Jan 04, 2009
We are paying for netflix. How do we get it on our television? Our television is connected to comcast and we have wifi?
But is your TV a "Smart TV"? That means does the TV connect to the internet. Just because you have Comcast connected to your TV doesn't mean it is getting an internet signal. The black coax to the TV only carries a TV signal.
To get internet service to your TV first you have to determine if it is capable. If it does have a wireless receiver in it, you will have to configure it to attach to your wireless base station. If it doesn't have a wireless adapter you will have to connect a network cable from the base station into the TV and then configure it to work with your network. Once you have that internet signal working on your TV you will be able to use Netflix on your TV.
Mar 01, 2015 | Netflix
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Router gives strong and weak signal in same place
If you think that your router signal is weak then you can follow the given points:
->Router positioning has an impact on the strength of a wireless signal. Brick walls and metal objects such as radiators, refrigerators and file cabinets can weaken a signal.
->Change the WiFi Channel
->Update firmware or drivers
->Reduce wireless interference
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
Nov 14, 2012 | Vizio Xwr100 Dual-band Hd Wireless...
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
I have a new dell 1545. I was able to connect to the internet for the first few days. I have bought a linksys usb that has given me an extra bar for signal. I have installed a netgear router which has...
Try linking your ethernet cable from your router to your notebook. If it allows you to connect via ethernet port, it definitly your wireless.
1st go into control panel, then Network and settings, then Manage wireless networks. Remove all other wireless networks on your computer apart from the one you are trying to connect to.
Once this is done, Go back to your control panel, Network and internet, then click connect to a network. Disconnect from the network you are connected to and then reconnect. This should solve your problem, please let me know how you get on and if you need any further assistance, please rate it this was of any help, thanks
Mar 07, 2011 | Dell Inspiron 1545 Notebook
So, I've installed my TEW-623PI and all of the related drivers, restarted my computer and it still says that it is getting good signal in it's utility, but in windows network center, it's only getting one...
Conflictions with the software, trying to tell you there is a better signal, thus increasing your trust in their hardware. Whereas Windows tells it like it is.
Sep 01, 2010 | Trendware TEW-623PI Wireless Adapter
Have good signal, keeps dropping off the internet
The problem here could be the Wireless Channel.
All you have to do is the following:
1. Log into your router at 192.168.1.1 that is the default unless changed by user,
2. Click on Wireless Tab
3. Change the Wireless Channel to 6 instead of 11 or change it from 11 to 6.
4. Apply settings and you shold be fine.
You need to do this because your router is conflicting with other wireless devices that are present nearby on the same frequency.
If this does not solve just try other Wireless Channels.
Thanks.
Hope this solves your problem.
Apr 04, 2009 | Linksys WRT54G2 Wireless Router
Cannot find local area connection to access internet
IF YOU HAVE A ICON OF A COMPUTER AT THE BOTTOM OF THE SCREEN IN THE BOTTOM BAR CLICK IT AND YOU SHOULD KNOW WHERE TO GO FROM THERE
Dec 22, 2008 | WiFlyer - Portable, shareable WiFi base...
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
