Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore elite 253.44509605 is buzzing
Is buzzing very loudly when the door to the freezer is closed or that button in the freezer is pushed.
4 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Posted on Apr 27, 2009
buddymcl777
  • 67 Answers
SOURCE: freezer door not sealing
replace the seals and / or have the hinge adjusted
Posted on May 01, 2009
  • 3600 Answers
SOURCE: kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Posted on Jun 18, 2009
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
Freezer door not sealing
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water/Ice Dispenser buzzes loudly as soon as freezer door closes.
I am not sure what would be buzzing, but besides the parts in this area that are worked manually, this means that the working parts are not electric they are manual working parts, the parts that are electric are the lights and a switch for different ice types, if you have this option. You can remove the cover
by pushing up on the plastic plate that surrounds the ice/water area with the lights on it, on the back you will see the electric connections to the chip board, you could unplug these connections and see if the noise stops. Now every fridg is the same so make sure there are not any screws holding the plate
on before you try to push it up so it can be removed. Any questions please post back.
Mar 27, 2009 | GE Refrigerators
Elite 73952 will not start
sounds like it is the motor, open the door and press the door switch in ,have another person push the start button,and you tunr one of the drun fins. IF itstarts, you need a motor
Mar 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
