Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-51HW40 T.V. it turns on for about 30 sec. then just shuts off all the lamps turn on and you here it click on then all of a sudden it just shuts off any help?
  • lthrgal44 Jan 07, 2009
    lthrgal44
    i turn tv on, the show comes on with a blue haze, the blue gets deeper then the picture turns off, not the sound.
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Jan 02, 2009
  • Sony Master
  • 5,138 Answers
Replace Both of your STKs convergence ICs they are big black ics they will have STK numbers on them STK392-560 ect. Parts you can order on line www.electronix.com or call 1-800-223-3205 you also need silicon heat sink white compound to put on back of new ICs. Use same # on stks but if they are 110s use 180s if 020s use040s.
Posted on Dec 27, 2008
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Dec 30, 2011 | Sony Televison & Video
I have a sony KP-51HW40 and when i turn it on about 5 minutes later it shuts it off.
If the TV works fine during the 5 minutes its on then your power supply in the tv is heating up and shutting off. If you have some mechanical knowledge you can buy another power supply from Ebay for around 35.00 and replace it. will require some soldering
Jan 23, 2011 | Sony KP-51HW40 51" Rear Projection...
I have a sony kp-51hw40 that I just received
This problems also cause by the 2 STK convergence ICS and some or all it resistor are dead.Require changing the 2 STK convergence ICS and some or all it resistors will solved this fading out and shuting down.
Jul 11, 2010 | Sony KP-51HW40 51" Rear Projection...
Screen turned orange, heard a sizzle sound tv
A capacitor has burned out. It may be on the motherboard or power supply.
Jul 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 fades to blue screen
you need change the ic in the soket blue [video out]
Aug 15, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
