My D-Link router does not recognize the IP address.
  • 100 Answers
Are u entering the proper ip address check it also reset the router 1st before entering the ip adress.reset switch is a small hole under below power plug in
Posted on Dec 26, 2008
I have a TP LINK router, it transmit signal properly. the problem is when the 3G USB internet modem is fixed into it, it does not send internet signal so the laptop shows TP Link signal: excellent, but no...
To solve your problem:
go here
http://www.tp-link.com/us/article/?faqid=92
Basically what you have done is plugged it in but did not set up the router on a static or dynamic IP address.
Once you have established the IP address of the router and it is recognized by your ISP device (DSL, Cable, Satellite modem ....etc etc.) then you have to decide which device will be the DNS server and assign IP address to all the wireless devices that connect to it.
Lots of things can be wrong. You need to follow the steps on the set up link i gave you properly and in the correct order
Oct 23, 2013 | Computers & Internet
All D-Link Dir configuration done but I can't access internet,why is that?
Reset your router back to it's factory settings by holding the reset button for about 5 seconds.
I have provided a list of the most popular router brands. If it does not work you may need to
google what your specific model's default IP address/default username/default passwords are, for
example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it
can depend on where you obtained your router. If you purchased it yourself from a store then the
standard defaults should work. If you obtained your router from your Internet Provider you may
need to contact your service provider. It also may depend whether it's an old or new model router
as well. And you may need to press and hold the reset button on your router several times before
it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is:
192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or
192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 06, 2011 | D-Link DIR-600 Router
My d link dlg400 router won't issue it's own
The default IP address for this router is 192.168.0.1. Try that. If it is assigning ip addresses to your computer, you can check under status of network connections by right clicking the lan connection, left-clicking status, then click the support tab. The IP address listed next to gateway should be your routers IP address.
Apr 29, 2010 | D-Link GamerLounge DGL-4300 Router...
My router is not working. i have to connect it directly to my modem
have you rebooted your modem after you plugged in your router? remember, your modem picks up you computer's ip address and stays with that address until it gets powered off and on. then it gets the ip address of whatever device you have plugged in to. if you plugged your router to your modem without power cycling the modem, then you won't connect other devices wirelessly because it does not recognize the ip address.
Feb 19, 2010 | ViewSonic WR100 Router
Router to Computer connection problem
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
If you are still not able to access it then press RESET button for 10 seconds it is in back side of router .Then you can access it with above default ip.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then you can DHCP there enable it then save settings and restart router.
Then set ip get automatic in your LAN proeperty set ip address get automatic.Then it get ip from router then it works.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 02, 2010 | D-Link AirPlus DI-524 Wireless Router
Reset ip , how
You can reset your router to factory defualts.
For that press RESET button for 10 seconds .
Reset button is in back panel of router.
Press it for 10 seconds.
Then connect router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
thne you can see configuration of your router.
Then you can change ip addreses in WAN settings.
Let me know if you need more assistance.
Nov 07, 2009 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Desk top/ethernet to linksys router not recognizing.
First connect that desktop to linksys with ethernet cable.
then set ip property to network adapter .
Set ip address ,subnet mask and gateway ip to ip property.
Set ip address as the ip of network like if router ip is 192.168.1.1 so set ip like 192.168.1.15
set subnet mask as same as your other computer.
Set default gatway ip as your router ip.
Then you can connect internet.
Thanks.
Nov 06, 2009 | Linksys Wireless-G WRT54G Router
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
Problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
