The base of my bullet is full of particles. can it be taken apart to clean
Yes its easy to take the Magic Bullet apart.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
SOURCE: I dis-assembled the base of my Magic Bullet to
You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
SOURCE: my magic bullet stops rotating
The Magic Bullet power base is designed with HIGH TORQUE MOTORS and it is NOT TO BE USED FOR MORE THAN A MINUTE PER USE.Otherwise its gonna last a long time. You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
SOURCE: Magic Bullet Blender Repair
i had the same problem,broken plastic drive gear.
solution ; sacrifice one of the blender choppers bases you use the least (usually the flat cutter)
hold the cutter blade with pliers or in a vice if you can and unscrew the rubber gear off the shaft in a clockwise direction -- CLOCKWISE--DIRECTION-- easy huh.
Now insert screwdriver to suit,(coss,phillips or flat blade type) into centre hole in underside base of power head drive unit. Hold unit firmly and now unscrew broken gear or brass centre piece left behind CLOCKWISE again off spindle.
Finally screw rubber gear back onto motor spindle in ANTI clockwise direction. DO NOT over tighten. Rotation of motor and drag caused by blending action tightens assembly with use.
Done. for pics follow this link
http://www.ehow.com/how_5137984_repair-magic-bullet-blender.html
SOURCE: My Magic Bullet has broken. I need to know how to get it fix.
This happened to me, and I was told by the company that I had to purchase a brand new base, that the plastic turning device can not be repaired. If it is under warranty, you may not have to pay anything but shipping, and maybe not that either. If you do not have the number to the company, go on-line and and search for it. Call the company and report what the problem is.
SOURCE: my magic bullet has lost the plastic bits that
