Question about Dual XDVD8181 Car Video Player
I need ribins
I need to find the ribins that connect the screen,buttons on the face, and to the dvd player from the motherboard.
  • travonigga Apr 12, 2009
    i need the wire that gos to the bottons
Http://newjersey.craigslist.org/emd/1065630948.html
Posted on Mar 17, 2009
I have a samsung dvd player that connects to my samsung flat screen tv. Every now and then someone uses the tv and i don't know how they work it but the info button then doesn't work. if i disconnect
Contact the Samsung service centre. It sounds to be a strange fault with Samsung brand TVs. http://electronicshelponline.blogspot.com/
Inform them the problem you faces with the TV. They will surely provide a solution.
Nov 25, 2014 | Samsung Televison & Video
The disk drawer does not open
Try pressing repeatedly the eject button while you turn on the unit. If it does not work
then it is a mechanically problem in your player.
You need to open the dvd player manually .
The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.
You need to place the rubber thread to proper place.
If you still face the problem then you need to replace spindle motor.
Hope this helps.
Shane
Jan 31, 2011 | Sanyo DWM400 DVD Player
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
Need help resetting "Eclipse UCNV884" player
ELECTRORAMA ELECTRONICS
HAVE THE BOOT CD TO FIX THAT PROBLEM ..
TRINIDAD.. PH # 662-6387...DAVID & DANIEL
Feb 08, 2010 | Eclipse (AVN7000) Car DVD Player
Can't play dvd
most dvd players for cars have a wire that is connects to the parking brake so you can't watch while driving. You can ground this wire, and the dvd will work. that maybe the problem.
Aug 04, 2009 | Pioneer AVH-P6600DVD Car DVD Player
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Zenith SMS1943S made 1995 Need code to switch to dvd status
nleebrooks,
1) check the RCA cable connection from your DVD to TV screen.
make sure that each cable is in the right place (for DVD player yellow cable = video/ red and white cable = audio) (TV screen: yellow cable = video IN /white and red = audio IN
2) from your TV screen locate and check for A/V IN socket. it's either at the back/front or side of the screen.
note: some of TV screen does have 2 A/V inputs
3) Facing the front of your TV screen, locate a button indicating "A/V" or "AV" or a box picture having a forward arrow inside.
note: if you locate the said button and your screen have 2 A/V inputs press the said button until the right input where you connect your dvd cable been set.
cheers,
mark
Jan 17, 2009 | Zenith C13A05LG 13" TV
Screen
try to reset button u will need to take off the face to see the reset button
Feb 13, 2008 | Kenwood KVT-717DVD Car DVD Player
Dual XDVD8181 Car Video Player Logo
201 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
