Question about Plumbing
The shower faucet will no longer allow it to get as hot as possible-as hot as it's been before
  • 2 more comments
  • gina4marykay Dec 27, 2008
    after taking the faucet handle off and messing with it a bit, the problem seems resolved. must be a valve problem, hope it's not a warning of bigger problems.
    thanks
  • JPproblem Mar 04, 2009
    I have the same problem.  When you turn to the central knob to hottest setting, it's not hot enough.  All other showers and faucets in house are ok.  Just the master bathroom shower.  The water heater is fine.  Shower handle is hansgohe brand.  When I take the faucet and plate off to look at valve, it is single valve from what I can tell.  How do I adjust to make it hotter mixture?
  • Ray Coon May 11, 2010
    What make of Shower Valve is it?
    Are you experiencing any other problems with the water getting hot at other fixtures?
    sanray
  • phil_m7 May 11, 2010
    Hi Gina4marykay,
    Does the rest of your home's hot water still get just as hot as before. It could be the water heater or the shower valve itself.
    Please follow up with details, Phil
    Scholar:
  • 68 Answers
Hi Gina4marykay,
Posted on Dec 28, 2008
Shower temperature fluctuating and will not stabilise
You haven't provided much information to help narrow down the source of the problem.
Is the flow of both hot and cold water flowing freely? Are the water lines not clogged internally with corrosion or residue? Is it possible that the water is being diverted such as in an apartment building or to an outside spigot (sprinkler system) or kitchen faucets (dishwasher)?
Is your water heater temperature setting correct and is it supplying sufficient hot water flow to the shower?
Do you have a temperature balance cartridge in your shower faucet? If yes, it could possibly be faulty.
Nov 07, 2014 | Home
I have a wireless Grohe shower that keeps dripping hot water constantly
Your mixing valve(faucet) has a bad valve and is allowing the hot water to bypass and leak thru shower. You should replace the bad mixing valve or the faucet to repair and stop the leak.
May 10, 2011 | Grohe Home
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
We have two showers with Delta single lever faucets. Both have given us problems. Both allow little or NO hot water through the shower head. What can we do?
It sounds like there's a blockage in the valve. It needs to be removed to see if water is blocked and confirm you have hot flowing freely.
Nov 23, 2010 | Delta & Single Handle Shower Faucet
Shower/tub combo hot water problem
There is a restriction in the faucet or the piping to the faucet on the hot wtaer side...this will be very hard to find and fix... The shower uses less water so it will get hot.... the tub spout allows more water flow so you cannot get the water more then warm...
Take the faucet apart and blow out all the passage ways with air... also run some water from the piping while the guts are out of the faucet, to flush the piping...
Hopefully this will fix you up...
Heatman101
Mar 03, 2010 | Delta & Single Handle Shower Faucet
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Water Temp not hot in shower
you need an allen key to remove the handle once the handle is removed than you need to turn the grey plastic temp guide counter clockwise as far as possible
Feb 01, 2009 | Delta & Leland Lavatory Faucet
Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Dec 30, 2008 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Plumbing Logo
102 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
