Question about Canon BubbleJet i560 InkJet Printer
Operator error. Press printer's RESUME button. If this doesn't clear the error, cancel printing and turn the printer off and then back on. How do I fix this error?
SOURCE:
  • 52 Answers
SOURCE: My Canon i 560 s will not print and this is the
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Posted on Jul 02, 2009
micromaster
  • 3614 Answers
SOURCE: Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Posted on Dec 12, 2009
pineworks
  • 4345 Answers
SOURCE: Yellow light keeps coming on and there is ink and
Hi
Problem for Canon BubbleJet i560 InkJet
The waste ink is in the inside of your printer you need to get at it to clean out,
It may be all screwed down so you need to open all up or get a shop to do it for you.
It not an easy job but maybe you are handy with a screwdriver, it can be messy job.
But after this, you will have to reset the waist ink counter or it will still not work,
But but but but you can always try this to reset it first and clean it out again some time.
Canon Reset waste ink counter
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
  • 164 Answers
SOURCE: Operator error. Press printer's RESUME button.
Start by totally shutting down your computer system, NO lights should be visible or blinking.Now completely disconnect all cables and cords from your printer. Remove the electric cord from the wall socket. This should totally clear your printer. Wait 5 minutes and plug the power cord into the printer first, then attach the printer cable that comes from your computer, then plug your printer power cord into the wall socket. Now cold boot your computer. It should recognize your printer and you should be good to go.
Posted on Mar 07, 2010
SOURCE: flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
Posted on May 30, 2010
I keep getting this error Operator error. Press the printer's RESUME button. If this doesn't clear the error, cancel printing and turn the printer off and then on again.
Go to start... control panel
look for printer and devices or something of that sort till you find your printer model.
Double click on the printer... you should see a doucument queue that is waiting to be printed...
Right click on all pending jobs and say cancel or delete....
Jul 25, 2010 | Canon BubleJet i965 InkJet Printer
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i860 printer not working
The error code says that your printhead is bad and needs to be replaced. QY6-0049-000 around $40.00
Jun 30, 2009 | Office Equipment & Supplies
Canon i9900 Error reads as follows. Operator error. Press printer’s RESUME button. If this doesn’t clear the error, cancel printing and turn the printer off and then back on. I've cycled through...
there is something inside the printer, i have the same problem and that was it, a paper or something blocking the headprint to run from right to left
Oct 22, 2008 | Office Equipment & Supplies
5 amber flashes
Operator error.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Canon BubbleJet i560 InkJet Printer Logo
276 people viewed this question
Clive
Clive
old marine
old marine
