Question about Sub-Zero 695/O Side by Side Refrigerator
Have an upright freezer. the door has a problem with sealing. the gasket is not cracked or worn in any spot but its as though the door is not closing tightly. perhaps a sprung hinge or something like that and if so how do i fix that The freezer compartment door closes tightly, but not the refrigerator area door. How can I fix this?
  • 3 more comments
  • massimiliano Dec 29, 2008
    Thanks for the suggestion. However, the cam closes the door on its hinges nicely, but the door then does not "**** in" tightly as SubZero doors notably do (and as does the door to the freezed compartment).
    I really appreciate the comments of 'classyexpert'. However, the freezer door is closing tightly and properly. It is the other door that does not pull in tightly after it swings shut. Any ideas?
  • massimiliano Jan 03, 2009
    Problem persists. Refrigerator door closes, but does not pull in tightly like the freezer door.
    Any other possilbe solutions?
  • massimiliano Jan 16, 2009
    Thanks for the suggestions. Problem resolved spontaneously after one week---while awaiting the National service person. Weird!!
    Sergeant:
    Champion:
  • 201 Answers
When you close the door its suppose to **** close, making it very difficult to open within a minute or so. Here is a suggestion turn out the feet of the 2 front adjustable feet, tilting it Little back wards so that it can help the door to stay close. You can also check if the hinges is adjustable, but I know not all of them are.
Thank you for using Fix-ya
Posted on Jan 03, 2009
  • 3,037 Answers
Hi massimilliano
This is going to sound simpler than it will be but you need to replace the hinges and brackets for the door. They can be ordered through the manufacturer or through an online parts supplier through a simple google search. If you need help finding a place to order new ones, let me know, otherwise good luck with this
bestdarngood
    Genius:
  • 1,199 Answers
The door sounds like it was bent in some way and needs to be taken off and fixed ...the hindges may also need replaced to get the proper seal back!
    Master:
  • 413 Answers
Make sure your hinges are snug and the plastic bushings are intact. If not the problem make sure the fridge is sitting level. It sounds like the top hinge or bushing needs tightening or replaced
Posted on Dec 29, 2008
  • 51 Answers
There are some screws attached near the bottom left hinge that help hold the seal in alignment. Loosen those screws a little, but not all the way. Try to push the seal in to re-align it, then tighten the screws back up. Might have to play with this a little to get the alignment right.
  • ME55ENGER Dec 29, 2008
    Please note that this is not a hinge problem I am describing, but screws that hold the seal allignement on the bottom corner near the hinge side. Sorry for any confusion there.
  • Sub-Zero Master
  • 19,396 Answers
  • Ginko
    Ginko Dec 27, 2008
    If it is a hinge you can see it, check if the door is at level, otherwise replace the gasket.
    Scholar:
  • 108 Answers
You could also try and get a replacement seal that they sell in bigger hardware stores such as Lowes or Home Depot it's pretty easy to replace and the magnets in them will give your door a good seal.
Another thing could be is someone hung on the door or alot of weight is on the door and twisted it a little bit which has happend to me in the past what i did is untwisted it where it's not making contact such as the bottom of the fridge door I put my foot at the bottom of the door and pulled the top a little bit til it moved and then it closed correctly.
Happy Holidays
Posted on Dec 26, 2008
    Sergeant:
    Novelist:
  • 327 Answers
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.  also click this link for more help This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
  • 15,935 Answers
Adjust the hinges on the door. With a model # & Manuf. we can better help.
Ice in bottom of side by side Kenmore freezer side
Make sure the doors are closed tight - freezer door may open a crack when frig side closes.
If door is tight, make sure the door gasket makes a tight seal. Often they need to be cleaned (409 is my favorite) or they get twisted. They also sometimes come away from the door in spots. Pay attention to the bottom seal which you usually don't notice in daily use.
Nov 03, 2017 | Kenmore Refrigerators
Why is my Hoover A Class upright freezer alarm light constantly on
1) It could be a short. 2) The thermo sensor that turns the light on could be defective and needs to be replaced.
Mar 24, 2015 | Hoover 9.9 cu. ft. / 280 liter Upright...
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Frigidaire freezer always running
Hi Edward - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Oct 13, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Our upright freezer door will not seal tight with a vacuum anymore. The freezer fills up with snow from the air drawn in. I have defrosted it and cleaned the seal. What should I do now?
That could be one of two things, one the door is not aligned properly and more important the gasket has failed and needs replacement. The snow as you call it is ice condensed from the atmospheric air that is getting by the gasket. You may want to check the door gasket and sealing surfaces especially in the area of the "snow".
Good luck,
Gilshultz
Dec 01, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
Top coil in upright freezer icing up
its a manual defrost freezer, it is normal to ice up, if it is unusually more than you have noticed over the past 40 years, see if the door liner is cracked around the screws under the gasket, if so put some washers there to reseal the door liner
Nov 01, 2009 | Freezers
Gasket doesn't seal at top of door.
you could use a hair dryer to attempt to remold the gasket to the door
other than that i think you would have to replace the gasket
May 27, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
New freezer has bad door seal
it often works to warm the seal with a hairdryer and reshape it
Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Sub-Zero 695/O Side by Side Refrigerator Logo
144 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
