I am locked out from my c:\ drive, i cannot save, delete or add new folders
  • 1 more comment
  • julio_rodrig Dec 26, 2008
    how can i fix it
    i accessed my computer file from there i went in to properties, next on the option menu i accessed sharing next thing was advanced sharing and from there deleted 2 accounts that had access to files. How can i restore or fix a way to have a full access again on my c:\ drive and file on my laptop. I need help please guys, thanks.
  • julio_rodrig Dec 28, 2008
    I have a Windows Vista Home Premium program on a Acer Aspire 9300-3716 laptop .i accessed my computer file from there i went in to properties, next on the option menu i accessed sharing next thing was advanced sharing and from there deleted 2 accounts that had access to files. How can i restore or fix a way to have a full access again on my c:\ drive and file on my laptop. I need help please guys, thanks.
  • 15,935 Answers
You are on a guest account without those permissions. Only an administrator can do that.
Posted on Dec 26, 2008
  • 6 more comments
  • blueextc3221
    blueextc3221 Dec 27, 2008
    You must sign in as ADMIN to Windows.
    START - CONTROL PANEL - USER ACCOUNTS
    there should be an ADMIN account. This is the only one that can allow or deny other user accounts to access/make changes to HDD.
  • blueextc3221
    this problem has nothing to do with Sharing. That is a networking permission. You have to allow or be on an account that allows changes to be made to the HDD....
    A user account in Windows XP is a profile that defines user rights, customizations and settings. By utilizing user accounts on computers with more then one user, each user is able to specify and retain their personal Windows XP environments.
    A user account defines the following properties:
    • Access rights.
    • Desktop layout.
    • Individual user favorites and history.
    • Use of a private “My Documents” folder.
    There are three levels of user accounts in Windows XP which are administrator, limited and guest. Each account has a different set of account rights. Listed below are the types of accounts and what rights are assigned to each account type.
    Administrative Account Rights:
    Only administrative level users have full system access including access to other user accounts. Windows XP requires at least one administrative account which was created during the Windows XP installation. This account is responsible for maintaining all other user accounts and system resources. Account rights are:
    • Install software and hardware.
    • Create, modify and delete user accounts.
    • Access all files.
    • Create or change passwords for all user accounts.
    • Modify names, pictures and account types.
    Limited User Account Rights:
    A limited user account is an account created for regular users of the computer. It is suggested that the administrator also created a user account and only uses the administrative account for system maintenance. Account rights are:
    • Do not have rights to install software or hardware.
    • Allowed access to already installed software.
    • Can modify own user account with exception of account name or type.
  • blueextc3221
    Setting Up, Maintaining and Switching Between User Accounts
    Add an Account:
    User accounts are setup, modified and maintained by the administrator. To setup or modify a user account:
    1. Start | Control Panel | User Accounts.
    2. Select Create a New Account.
    3. Type account name.
    4. Select account type.
    5. Click Create Account.
    Modify an Account:
    From within the user account an administrator can add a new user or make changes to an existing user such as resetting password or changing the user name.
    2. Select Change an Account.
    3. Select Account to modify.
    4. Choose which account attribute to change.
    Switch Accounts:
    To switch between user accounts there are two options:
    • When first logging on select the appropriate user account.
    • If computer is already on then click Start – Logoff then select appropriate user account.
    There are many situations that setting up multiple users can be beneficial. Some examples include:
    • A home computer that several family members use.
    • A work computer that is used by different employees.
    • A work computer that is used by a temporary employee.
  • blueextc3221
    blueextc3221 Dec 28, 2008
    if you were able to change the accounts (deleting them) you are an admin. Open the account you are signing on to and be sure you have admin rights.
  • blueextc3221
    As Windows XP makes serious inroads into the home and small office/home office (SOHO) market, frustrated power users are asking me a lot of questions. The most common question is "What happened to the Administrator account?"
    Two situations typically give rise to this question. The first is when someone running XP tries to install a legacy Windows 2000 or Windows NT application that will install or run only under the Administrator account. The second situation occurs when someone configures a home computer to allow limited access by children or other family members and wants to maintain full access for only the Administrator account.
    If you're using XP Home Edition and want to maintain an Administrator account, you might have a big problem. In that OS, the Administrator account is available only when the computer runs in Safe Mode; you can't create an Administrator account that's available in any typical mode of system operation. This limited availability hinders the Administrator account's effectiveness in managing the computer.
    If you're running XP Professional Edition, you can easily gain access to the Administrator account if you give up XP's Fast User Switching capability and use the classic Win2K-style logon screen, which isn't available while Fast User Switching is activated. To access the classic logon screen, go to the User Accounts application in the Control Panel. From the "Pick a task" list, click "Change the way users log on or off." Clear the "Use the Welcome screen" check box (this action automatically disables Fast User Switching as well) and click the Apply Options button. Then, log on to the system using the classic logon screen, and you'll be able to enter any account name you want to. When you open the User Accounts applet in the Control Panel, you'll see that the Administrator account is now visible.
    If you've been using XP Pro in a domain, Fast User Switching is probably new to you; when an XP machine joins a domain, it loses the ability to use Fast User Switching because the domain logon requires the classic logon interface.
    In most cases, I don't think you lose much functionality by disabling Fast User Switching. I've yet to hear from anyone who wanted to be able to keep their applications running in the background while someone else used their computer, which is what Fast User Switching lets you do. I'm sure situations exist in which Fast User Switching has value, but I've been using XP daily for almost a year, and I've never felt the need to use Fast User Switching.
  • blueextc3221
    Download the Windows XP powertoys from Microsoft's site. The program contained within, TweakUI, let's you add the administrator to the XP Welcome Screen with the other users' icons.
  • blueextc3221
    If you really want to login into as administrator, you will have to restart the computer then you must to press F8 during boot (you can just keep pressing it repeatedly) and selecting the SAFE MODE then you press the enter. It is all you have to do!
  • blueextc3221
    To reset the administrator account: Click on "start", click on "run" type "compmgmt.msc" and click "OK". In the "Computer Management" window on the left, click on "Local Users and Groups", then click on "Users". Next, "right-click" on the "Administrator" account and select "Set Password..."
    To disable windows from automatically booting in to an account, do the following: from the start menu, run regedit.exe and go to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\" change the value of "AutoAdminLogon" from "1" (the number one) to "0" (the number zero). You can also temporally bypass the auto logon on startup by holding down the shift key once the GUI starts to load (but before the user is automatically logged on); the startup process will then stop at the "classic logon prompt" and ask you to login. Changing the following registry value: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\DisableCAD" from 1 to 0 will require the user to press "Ctrl+Alt+Del" at the "classic logon prompt" to logon to the system.
It gives error that your hard drive have 1mb free space
1. Go in control panel Add or remove programs or programs and features then uninstall the programs that you don't use or havn't used in a long time.
2. Go in control panel Folder options view tab at the top. Look for Hidden files and folders put a tic in show hidden files and folders.
Go in My Computer/Computer Click on the c drive then windows folder delete the update folders that have a $ infront of the name of the folders. Go back to Folder Options/View tab at the top. Hidden files and folders put a tic in Do not show hidden files and folders.
3. Right click on Rec bin choose empty rec bin.
4. Go in control panel / Internet Options clcik on settings next to the first delete button from the top then click on view files. On the upper roght clcik on edit/Organize choose select all. Then hit your delete key on your folder yes to conferm. Click on ok then in the next window click on delete button next the settings button you clicked on before.
5. Open notepad type del %temp% /q then save the file to your desktop name it Del.bat cloce everything out and double click the del file on your desktop.
6. Open the run command Hold the windows key down (left of the space bar on your keyboard) Press the r key. Type in %temp% Delete all the files and folders you can in that folder.
7. Right click on Rec bin choose empty rec bin.
If it still says low disk space I suggest saving your personal files and reinstall your oem system disk or add a second disk drive.
Terry
Apr 03, 2014 | Computers & Internet
Flashdrive keeps deleting
With all the hours and effort put into progressing in a video game, protecting your saved files becomes an important matter.
Creating a backup on a flash drive ensures that your game will be preserved. Having a copy is also handy if you get a new computer or if you merely want to keep your character safe for a sequel that allows you to import your progress from a previous game.
While you cannot save a game to a flash drive while playing, transferring or copying a saved game file to a flash drive is a simple process.
Locate the saved game files on your hard drive.
The location will depend on the game that you are playing (see Below)
Tips & Warnings
BioWare games save within the "BioWare" folder created in the My Documents folder.
Most games purchased through Steam will be saved under Program Files>Steam>Steam Apps>[Username.]
A Game independently installed will likely create its own folder within Program Files.
You may need to visit the game developer support site to help track down that game's specific location.
Open your flash drive.
Click and drag the entire saved game folder to the flash drive to make a copy.
Depending on the amount of file data, this may take a few minutes to complete.
Do not delete this folder on your hard drive or uninstall the game until you have verified that the saved game files work on other computers.
To transfer the saved game, plug the flash drive into a computer with the same game installed. Open your flash drive. In a separate window, open the same directory location where you found the saved game on the other computer.
Click and drag the saved game folder on your flash drive to the game folder on the new computer.
If a window pops up asking if you would like to overwrite similarly named files, click "Yes."
Apr 19, 2013 | Call of Duty Black Ops II 16GB Badge USB...
On my hand set l was not save internet configaration when i was saved it call only 70 set allowed save disscarded .now what was my solution
hello bro
Just Follow the following steps to save your configuration settings.
1: Download & install OxyCube.
2: Connect your phone with USB cable. (USB Cable drivers must be installed)
3: Run OxyCube.
4: Select C: (Your phone memory).
5: In folders tree select Omadm Folder.
6: There will be 70 Numbered folders under Omadm.
7: Delete all folders accept first 5 & the folder named PRECFG.
8: Disconnect your phone.
9: Reboot your phone.
10: Either request you provider to send you settings. or insert it manually.
11: This time the settings will save normally.
Mar 07, 2011 | Nokia 6300 Cellular Phone
I can not add any folders or delete anything off of my free agent
if this is a emoty drive formatit by rigth clicking on it in mycomputer
Jun 04, 2010 | Seagate (ST3320820U2-RK) 320 GB USB 2.0...
My PS3 wont recognise 3.15 update from usb, formated usb to fat32 nothing works. Trying to swap the drive did the recomended instruction change and the system wont restart the new drive,went through all...
tilz1
If your PS3 will not see the update most likely you did not save the file to the right place.
The link below is the the main instructions to properly do the install of the firmware update. However when you save the you will wanted to save the update in a folder named "PS3” on the root directory of the USB drive. Then in that folder make a folder called “UPDATE”. After you have done this then you will want to save the update in the “UPDATE” folder. Doing this should allow your PS3 to see the update.
Let me know if you have any more problems or questions
Issken
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
It says that free memory is about 1.5 mb and the
To organize your messages, you can move some of them to the Saved items folder, or add new folders for your
messages. While reading a message, select Options.
To add or delete a folder, select Menu > Messages > Saved items > Text messages, and My folders. To delete a
folder, scroll to the folder, select Options > Delete folder.
Let me know if this helps
Nov 26, 2009 | Nokia 6030 Cellular Phone
How to save folders containing files onto a memory stick
using a pen drive is not a tough job
just plug it in to the usb port and wait for a few seconds
*you will see a baloon tip saying found new hardware
*wait untill it says device installion complete
*reboot if neccessary
now go to my computer
*you will see a new drive in it(it is your usb pen drive)
*double click to open it
you can acces it like your normal hard drive partiitions
if you want to copy something to your pen drive then
*right click on the file or folder
*select the option "send to"
*your pen drive will be listed in it
*click on the name of your pen drive
*wait for copying to finish
after that go to my computer open the pen drive and see if the file is copied
you can also delete the files in your pen drive
*select the file
*press delete in the keyboard
files deleted from pen drives dont reach recycle bin
Apr 13, 2009 | Computers & Internet
Making new folder and copy folder from harddrive to flash
On most flash drives there are locks that are called write protect locks. Its a switch on the drive itself that prevets you from saving on it.
Jul 27, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I cannot access western digital 1000 gb
Here is a tedious solution that works. Use MioNet and move all the files you want to keep to another drive or another computer, then delete everything from the MyBookWorld. Remove MioNet from all computers. Next access the drive's built in Shared Storage Manager with a web browser. Check the pdf manual on the install disk to find out how. Create a new shared folder and then move everything you want on the drive into the new folder WITHOUT using MioNet. Map the shared folder as a network drive for easy access. Never, ever, EVER use MioNet again and all should be good. The drive works, the MioNet software does not.
Feb 19, 2008 | Western Digital 500GB My Book World...
Computers & Internet Logo
78 people viewed this question
Alun Cox
David Payne
David Payne
