Question about Aspire Acer 53152826 Notebook
Notebook boots up and then screen goes blank
Battery power light on, main power light on, notebook making noise like booting up. Screen goes black...nothing works. Can use F2 and F10 to access but doesn't seem to do any good.
Help?
  • dodonoghue7 Dec 27, 2008
    I get initial page and can get boot menu (F2) if I press it before screen goes blank. I've tried to set it back to default settings but it continues to go blank. Any suggestions?
  • Brian Ebeling May 11, 2010
    when does the screen go black?
    does anything appear on the screen before or is it always black?
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
GATEWAY mt3422 WILL NOT BOOT UP. Power light is
if your harddisk is ok than , u open your notebook motherboard and clean processor fan properly,,than again fitting your laptop than boot from cd rom (make sure that your cd rom is ok )
Apr 14, 2010 | Gateway MT3422 RTL Notebook
Blank screen on boot up no hd activity
try removing the lithium "Bios Battery" and leaving it out overnight then the next morning put the lithium battery back in.
Jan 04, 2010 | Everex StepNote NC1500 Notebook
AMD Puma-based Asus M51Ta stalls at power up, screen is blank.
Have you tried booting and pressing F2 to get in the bios?
If that works you can check the boot devices and order of usage. Make sure the HDD is first.
Apart from that you can reboot and press F8 to get in the Windows boot menu, where you can try the Safe Mode.
If all this fails, the Windows configuration is somehow corrupt. You can try booting from a Windows CD and run the Repair option in the setup.
Oct 20, 2009 | ASUS M51Ta-X1 NoteBook
Notebook won't start/lcd is blank but the power is on
You could have a faulty motherboard or RAM.
First remove the main battery and boot up the laptop without the main battery connected, if it boots up insert the battery, no need to power down. If that doesn't work, switch off/disconnect the adapter and insert the battery, then reseat the RAM modules and boot up.
If nothing works then you have a piece of junk. You can salvage the hard disk and put it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 12, 2009 | ASUS M51Sn-A1 PC Notebook
When i switch on the my thinkpad it starts to boot up then the screen goes blank the battery light goes orange and and flashes and it makes a cranking noise.
Is the Battery making the cranking noise? If so the battery is telling you the battery is dying. I have a IBM ThinkPad 380Z and when on the charger it makes a beeeeep noise and goes off and on for almost the entire day and then stops and keeps a solid orange battery light on.
Try booting without battery
Feb 23, 2009 | IBM ThinkPad T40 2373 Notebook
The notebook will not boot up. When the button is pressed, it lights up for about 10 seconds and then goes off. There is a faint hum which sounds like the fan starting up but that also stops when the...
sound like you have power problem mostly that is happen to the hp notebook now to solv
now you need to unplug the ac power and also remove the battery and press the power button and hold untell the light come on and plug it back in and also put your battery back on the notebook should work normal again
Dec 10, 2008 | Acer Aspire 7720 Notebook PC
Amilo pro v2055 blank screen
Remove the battery and the power supply. Hook it to wall power only w/o the battery and try to turn it on. If it boots great, otherwise pull the power from the unit while it tries to turn on. Plug it back in and try turning it on again. If that doesn't work you need to re-seat the RAM and/or processor. Last thing to try if that doesn't work is new RAM as a processor almost NEVER goes bad and it is either the RAM or the motherboard at that point.
Nov 10, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Notebook goes blank
your battery may be getting to weak to work.
try booting without the battery.
Apr 26, 2008 | Computers & Internet
Aspire Acer 53152826 Notebook Logo
83 people viewed this question
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
