Question about HP Office Equipment & Supplies
FAX machine hook up and operation
I have a hp fax machine (HP officejet 7110 all in one) part #SG36PDION56G and only have the RJ45 phone cord fo it. Where do i obtain the other cords necessary to hook it up. ie: power cord and any other RJ cords necessary. The installation and operation documents would also help. ThanksRick O
  • 2,120 Answers
You need a RJ-11 phone cord and a USB A/B cable.
Once you have it hooked up go to in the printer suppot area. HP will download the printer drivers automatically.
Posted on Dec 27, 2008
I have hp 6500 a plus wireless what phone cord I need to work fo that
For any RJ !! type cable/cord may be used and connect to the printer where marked LINE.
Feb 24, 2015 | HP Officejet 6500A Plus
I have a HP 4315 officejet all in one and it prints fine...but when i try to fax a page it fails every time...why?
Good Day Sir, I have a solution to your problem, hope this will help you.
"HP 4315 officejet fax failed"
  • Turn off the machine by using the ON button and then unplug the power cord from the back of the machine. After a few seconds, plug the power cord back in and turn the power on.
  • Try to send or receive a test fax.
  • If you are running the test from the Fax Setup Wizard (windows) or Fax Setup Utility(Mac), Make sure the Machine is not busy completing another task, such as receiving a fax or making a copy. Check the display for a message indicating that the machine is busy.If it is busy, wait until it is finished and in the idle state.
  • Make sure you use the phone cord that came with the machine. If you do not use the supplied phone cord to connect from the telephone wall jack to the HP All-in-One, YOU MIGHT NOT BE ABLE TO SEND OR RECEIVE faxes. then after you plug run the test again.
  • If you are using a PHONE SPLITTER, this can cause faxing problems. connect the machine directly to the telephone wall jack.
run the test again to make sure it passes and the machine is ready for faxing.
Goodluck and God bless.
May 22, 2010 | HP Officejet 4315 All-in-One Printer
My HP 6310 printer / fax is too far away from the phone line. Is there a way to fax wirelessly using this printer?
Only if you have fax software on your computer and scan an image to the computer to fax, otherwise you need a really long phone cable you can buy at Radio Shack or Best Buy.
Oct 29, 2009 | HP OfficeJet 6310 All-in-One Printer...
How do you erase the fax memory on an HP 7110?
Run the fax setup wizard to clear any personal information.
Or you can do it using the control pannel of you printer
Aug 14, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Problem receiving faxes with hp officejet 7110
Most likely it is a phone line problem, not ypur machine. Fax modems work or they don't work.
make sure your phone line is not digital.
Mar 16, 2009 | HP OfficeJet 7110 All-In-One Thermal...
I have never hooked up my fax portion of the 6100 hp.
You should have a dedicated ANALOG phone line.
Hook phone cord from wall jack to LINE port of the fax machine.
Ready to fax.
Jan 30, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet v40 - Not Faxing or Receiving
I have checked all my connections and my hp office jet v40 is giving the message off the hook though the phone it is connected to is not off the hook.
Aug 14, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Cant't send out any faxes.
Are you using the little cord that came with the printer to hook up your fax. It is a special cord. You cannot just plug a phone line into the fax.
You have to use the little cord, or equivlent. Go to
Apr 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hp officeject 7410 fax
Check to make sure all the phones attached to that phone number are on the hook.. sometimes an answering machine can create a problem also.. if you really want to check the printer / fax machine out, just remove all the phones that exist on that phone line and leave the fax machine connected. once all the phones have been removed and the 7410 is still acting up, you might have a bad fax card in the printer.
Mar 21, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hi, have you connect your OfficeJet to one of your telephone outlet using a phone cord(usually provided with a AIO printer)? Fax requires analog phone line to operate. If you have a corded phone, you could disconnect it and hook it up to your OfficeJet.
Once you got it hooked up, try dial a # to your cellphone so you know it's dialing properly.
Good Luck!
Jan 09, 2008 | HP Officejet 5610 All-In-One InkJet...
81 people viewed this question
Ben Johnson
