Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Dishwasher not draining - spilling over floor
I just installed a food disposer.It is working fine.
Unfortunately the first time I had not knocked out the plug in thedishwasher drain connector and when I turned on the dishwasher it spilled all over the place.
I dissassembled everything and knocked out the plug and reconnected everything as before.
The dishwasher still is not draining and spilling on the floor.
Any suggestions would be greatly appreciated
  • 250 Answers
Disconnect the hose from the disposer and see if the dishwasher will drain into a bucket. If it does, there's still a blockage in the disposer nipple. If no water still comes out of the hose, you need to pull out the dishwasher to see if the hose disconnected from the dishwasher's drain itself.
Posted on Feb 24, 2010
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
I installed a new food grinder under the sink. I also replaced the dried out rubber hoses that connect the food grinder to the dishwasher. But no matter what program I use, the dishwasher refuses to drain...
Check to make sure you removed the plug inside the garbage disposal inlet where the dishwasher drain hose connects. This is a common mistake installers make when installing a new garbage disposal. Make sure the power the the disposal is secured and remove the drain hose. Place your finger inside the inlet on the side of the disposal. The opening should be clear. If not, you simply need to insert a flat blade scewdriver through the inlet connection and tap out the plug with a hammer. The plug will pop out inside the disposal, so you will need to reach inside and retrieve it before attempting to use it. Once the plug is removed, reinstall the drain line and test operate your dishwasher by starting a cycle. Once the dishwasher fills and begins the wash cycle, press the STOP/CANCEL button to initiate a drain cycle. Your dishwasher should drain with no problems. If you have any questions, please post back and let me know. I hope this helps you.
Nov 19, 2010 | Whirlpool Dishwashers
After I installed my Badger 5 my dishwasher would not drain. Is there a plug in the dishwasher port on the side of the disposal and how do I remove it?
There is often a plug in the ISE as many people use them without have a dishwasher connected to them. Quite often it is just a thin plastic membrane that can be knocked out with a screwdriver. There should also be a note to this effect in your installation instructions for the ISE.
Sep 14, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Food particles remain in the dishwasher and on dishes
Hello, if someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
If you recently installed a garbage disposal there is a knock out that many people forget to do on the disposal that, if you don't knock out will cause some of the risidual food from the disposal to seep back into the dishwasher...thereby causing particals of food to remain on dishes.
Thanks
Jun 17, 2010 | Dishwashers
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
My dishwasher doesn't drain? what can i check
How long it was installed? recently? Perhaps the installer didn't:
- Knock out the plug from the food disposer.
- Didn't check for kinks in the drain hose.
Installed a while ago?
- Check the drain hose, look for clogs, kinks
- Check the pump in the dishwasher (under), perhaps broken glass or small bones are jamming the drain pump.
Dec 17, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Bought a new dishwasher and cant figure out why it wont drain
Hi, Curious, does this unit have a drain hose connected to a garberator/food disposer ? If so, make sure the drain "knock out" has been removed from the garb/disposer. If that isn't the problem, make sure the neccessary "hi loop" has not been removed from the tub of the dishwasher. A lot of times during installation people remove the "hi loop" to gain an extra foot or two of drain line, but it's a no-no. You can also check for wires off at the drain pump. Hope that helps, let me know. Good luck. macmarkus :)
Nov 12, 2009 | Frigidaire Dishwashers
I installed a new bocsh dishwasher and garbage disposal. The water is not draining. I routed the drain hose on the floor rather than looping it up the back of the dishwasher, due the short lenght of drain...
If you did not remove the plug from the disposer drain where you made your drain connection will cause the dishwasher not to drain. This should have been mentioned in your installation instructions. Also, routing the drain hose other than what is specified in the instructions, will allow food waste to enter the dishwasher when you grind food in the disposer. Read your instructions and don't take shortcuts, you want to have your appliances work well for a long time, as you have made a considerable investment in some quality appliances.
Hope this helps!
Jul 16, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
LEAVING WATER IN TUB
I think your problem is in the garbage disposal unit. There is a knock-out seal in the outlet on the disposal unit where the dishwasher drain tube attaches. If you don't remove the knock-out then there is nowhere for the dishwasher water to go, and it will spill out onto the floor.
Apr 05, 2009 | Dishwashers
BOSH won't stop draining
take your dishwasher out and look for a water at the base of your dishwasher.
If that is a water at the botton base, just dry the water and its ok.
if you dont find water at the botton base inside replace the water level system PN= 263834 at repairclinic.com, item# 935595 for 41.00 and that part goes in the left side of your dishwasher
May 24, 2008 | Bosch 24 in. SHX46A05 Stainless Steel...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
104 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
