Question about Canon PIXMA MX850 multifunction InkJet Printer
SAYS PRINTER IS JAMMED; YET NOTHING IS IN THERE.
Printer working great, then changed paper from 8x10 to 4x6 and that is when the problem started. In computer, I also may have switched print to landscape; which now I read I should not do.? I have thouroughly looked at printer, nothing is jammed inside.
thank-you
  • 741 Answers
Normally turning it off and back on resets the error code. However, lots of times they may be a small piece of a paper stuck causing the error code. Turn the printer off for about 10 minutes, see if that clears it and check one more time for some paper jam.
Posted on Dec 27, 2008
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
My printer is now 2 years old. Always done great, nothing happened. But now he can't get the A4-paper out of the tray. He trays to grab the paper, but it doens't work. Photo's out of the photo-tray is...
Looks like you have a paper jam problem.Pieces of paper are stuck in the roller.Go to Control Panel ->Printers and Fax -> Select you printer and click properties.You will find a Printer Maintainance Wizard,which will have a paper jam clearing wizard.Click this and your printer will work as good as new.
Thank You.
Feb 20, 2011 | HP Photosmart D7160 InkJet Printer
Hello, My printer says that I have a paper jam but I can't find anything. I took all the paper out and put it in again. I turned the pirinter off and on. Nothing works. The page that originally got stuck,...
Great job on taking out the paper jam without tearing it. Maybe the sensor got stuck and printer keeps thinking it's still has a paper jam. Remove the ink cartridges from the printer. Close the cover. Unplug the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging it back in the printer. When the printer's ready, reload the cartridges then close the cover. If this doesn't help, I strongly suggest you contact Lexmark technical support to further investigate the problem. Thanks
Aug 04, 2010 | Lexmark X4650 InkJet Printer
Paper jam error nothing appears to be in there.
Kept messing with the printer. Took some of it apart. Changed out cartridge. Still found no jam. Turned it on and off multiple times.
Finally it worked. Prayer is all I know that worked.
Dec 30, 2009 | Canon PIXMA MP130 All-In-One InkJet...
My CX9400Fax printer has a paper jam every time it tries to print. As the paper starts to feed into the printer, the bottom left pulls in and the paper is then feed in crooked causing a paper jam every...
hi
hey i had the same prob til about 5 minutes ago ,, i kept pulling and playing with the jammed paper under the lid where you change the ink,, and finally on the left side ,,a blue piece of soft plastic material came out ,,now it works great ,,i have no idea where it came from but maybe it will help you lets hope
Dec 13, 2009 | Epson Stylus CX9400 Photo Printer
Canon mx700 won't print displays error306
Open the top of the printer as if you were going to change the ink cartridge and push the cartridge to the left. Reach your hand inside and see if the paper from the jam is truly out of there. Sometimes when you pull the paper out the front or back from a paper jam there can still be something stuck inside that is gumming up the works.
Jan 06, 2009 | Canon MX700 Office All-In-One InkJet...
Canon image runner irc 3100 transperancy paper jam
if you can open the printer you can access the rest of the paper other wise look in back for any part which can be opened and remove the paper jam
May 13, 2008 | Canon PIXMA iP1800 Printer
Printer says it is jammed
unplug printer from wall for 12 secs and plug back in
Jan 15, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
False Paper Jam
I have a problem with a canon printer MP460 its saying I have a paperjam but there is no paper to be seen cartridges move back and fore manually with ease please help
Nov 04, 2007 | Canon MultiPASS MP700 All-In-One InkJet...
Canon PIXMA MX850 multifunction InkJet Printer Logo
100 people viewed this question
old marine
old marine
