Question about Panasonic DVD-LV55 Portable DVD Player with Screen
Player problem My DVD_LV55 wont play. I turn it on , it starts ti read the disk. I see zeros in the displayed. After that nothing. can i try to reboot it or something?
  • 30 Answers
SOURCE: My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Posted on Mar 27, 2006
  • 277 Answers
SOURCE: panasonic dvd cv35 troubleshooting
hi first try unpluging the device for a half day and see if the problem repeats itself the manual recommend to ask for a technisihion to repair the unit before that try this: take a can of compressed air with a narrow hose open the discs drawer try to locate the laser eye with some light and clean it it should do the job good luck
Posted on Apr 03, 2006
  • 12 Answers
SOURCE: Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Posted on Sep 28, 2007
SOURCE: wont play discs
couls u help me
Posted on Dec 11, 2007
SOURCE: DVD Tray will not open
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
Posted on Jan 16, 2008
SOURCE: not reading dvds or cds
press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE until innitiliazing appears try several times
Posted on Apr 12, 2009
0 characters
1 Points
2008 cadillac 6 disk dolby dvd/cd sound system will not play or eject disk
Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Dec 02, 2012 | DVD & Blu-Ray Players
Only says loading when started, does nothing
Hi, your problem is the laser lens, it went sour. This device is coded to read only region 1 disks, when U attempt to read other regions disks it will read them once, 2 or 3 times but then... it will stop reading any disk regardless the region they are. Regions codes were implanted on disks to control piracy, so USA has region 1, Mexico 4, Asia I believe is 3 and so on. There are a total of 6 regions worldwide, U have to get disks matching the region U are from or, better solution... get a multi-region DVD player.
Jun 23, 2009 | TruTech PVS12701 Portable DVD Player
Dvd player wont play
Make sure that the DVD Disc is of the format that your DVD recorder can read. For example, if your recorder specifically requires a DVD -R type disk, it will puke on a DVD +R disk.
Apr 12, 2009 | Emerson EWR20V4 DVD Recorder/VCR
HO2 Error???
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Apr 14, 2008 | Panasonic DVD-RP56 DVD Player
This weekend we were watching a movie. It started to skip. I thought it was a dirty disk, took it out, cleaned it with a dry cloth and put it back. Now nothing will play.
When I insert a disk it starts to revolve the machine says reading, two zeros appear and the it stops. My wife noted a message H02 and the manual says to call for an explanation.
We tried turning the machine off and on and we tried pulling the plug -- no luck. What is the problem?? Jeff
Apr 06, 2008 | Panasonic DVD-RP56 DVD Player
Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Jan 05, 2007 | Apex Digital PD-450 Portable DVD Player
Panasonic DVD-LV55 Portable DVD Player with Screen Logo
26 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
