Ryobi Multi-Volt Battery Charger
Problem for Ryobi Multi-Volt Battery Charger
18 volt ryobi battery charger...green & yellow lights come on wha
By sonnys9986 on Dec 26, 2008
18 volt ryobi battery charger...green & yellow lights come on what does that mean????
Same Problem
Mar 29, 2009
-   I have 2 batteries and one charges, so I'll rule out the bad charger. I'll try cleaning the contacts (unplugging first) and see if it goes red. If not, it'll go back to be responsibly disposed of. -   Guest
Best Solution
posted on Dec 31, 2008
Very Helpful)
rowdy45176
Rank: Guru  Tools - Building & Power  Expert
Rating: 91%, 553 votes
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
Was this helpful?
Yes
No
Solution #2
posted on Mar 22, 2009
Not Rated)
gerard81
Rank: Apprentice  Tools - Building & Power  Expert
Rating: 100%, 2 votes
The same thing happend to my charger, i bought na new battrey, and now it charges normal again
Was this helpful?
Yes
No
Popular Solutions for Ryobi Multi-Volt Battery
Questions and Unsolved Problems for Ryobi Multi-Volt Battery
Do you recommend Ryobi Multi-Volt Battery Charger?
Answer
Answer
when i plug in the battery to recharge the two lights on the left light up and the battery does not... (More)
Answer
Yellow & Green Lights stay on. battery is fully discharged.
Answer
One of the front power jacks will not work. The motor side works great. The orthe side the gear on... (More)
Answer
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were... (More)
Answer
i get a yellow light with some batteries
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ryobi Multi-Volt Battery...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
