Question about Vivitar ViviCam 3705 Digital Camera
Vivitar Camera 3705B
I cannot take pictures because the batteries die shortly after they are in the camera. How do I stop this problem?
5 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: Vivital digital camera 3705b--manual/instructions
You can download the manual here:
http://www.retrevo.com/s/Vivitar+Vivicam+35?rt=pd
You will need to enter in your email address.
Here is the link to download the drivers for device:
http://www.jamesotr.com/Vivitar35CamDriver.htm
Good luck & don't forget to come back and rte my solution for you.
- Jim
Posted on Jan 25, 2008
SOURCE: Blinking Red Light
just push the button one or two more times at will take a picture while the light is blinking red.
Posted on Apr 29, 2008
SOURCE: Digital Vivitar Camera
i want vivitar 3615 camera software drivers to be download free version. where can i get it
Posted on May 05, 2008
  • 11967 Answers
SOURCE: Camera died while taking pictures. Lens is open.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 04, 2010
Need a Vivitar VC5050 installation disk - I think!
You don't need to install the camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 08, 2012 | Cameras
Tip
This camera sucks. It takes horrible pictures, you know the 2 or 3 you can snap...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Apr 25, 2009 | Samsung Digimax D53 Digital Camera
I need the software that was supposed to be included with the Mini Digital Camera from Vivitar,before the battery dies and I lose all 20 pictures I took.
Even if the battery dies, you won't lose your pictures. Did you get a CD with the camera? Usually, the owner's manual is on the CD. You can also go to the support section of the Vivitar website and download a copy of the manual and sometimes the software from there.
Apr 17, 2011 | Cameras
My son got a vivitar vs18b camera. The packaging says Mac compatible but when we put the image zone disk in nothing happens. I've tried clicking on the 2 files after opening the disk icon and nothing...
Try to get your money back for the camera. If not, go buy your son a better camera. Vivitar has no drivers for anything. Only what comes with the camera (WinXP only). Plus the viewfinder is junk, and the camera loses all store pictures when the batteries die or are removed. My son got one of these for Christmas, and I have never seen a worse piece of junk.
Nov 10, 2010 | Cameras
Vivitar 8010 camera wont turn on, but has power, red light is on.
I suspect you battery has died,this happened to me the other month.
Easily fixed by buying a new battery, got mine off Ebay £7.99
May 05, 2010 | Vivitar ViviCam 3915 Digital Camera
- Jim
Jan 25, 2008 | Vivitar ViviCam 35 Digital Camera
Blinking Red Light
Dec 05, 2007 | Vivitar ViviCam 3705 Digital Camera
Vivitar ViviCam 3615 Digital Camera
i have a vivitar vivicam 3720 digital camera need sofewear
Nov 13, 2007 | Vivitar ViviCam 3615 Digital Camera
Vivitar ViviCam 3705 Digital Camera Logo
49 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
