Question about Amana Refrigerators
Fridge losing cool
Our 8 year old amana fridge had a compressor replaced last year...now the fridge stopped cooling, but the freezer seems to be fine. I thought maybe the defrost timer failed, but then why does the freezer seem to be fine?
thanks
Jim
  • 1 more comment
  • greensageco Dec 26, 2008
    smithbrother:
    yes, I suspect the fan is inop, as there is no airflow into the fridge, although there is cool airflow to the freezer. thanks
    Jim
  • greensageco Dec 27, 2008
    I found a snap connector that became disconnected...that connector runs the fan in the freezer to the fridge..the guy who replaced my compressor didn't snap it properly.....looks like things are find now... thanks
    JR
  • Thomas F. Schneider May 11, 2010
    Most fridges have a fan that bvlows the cool from the freezer section to the refrigerator section. Have you looked to see if the air is blowing into that section?
    President:
  • 2,692 Answers
If I was of assistance please vote, Thank you.
Posted on Dec 27, 2008
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
Fan and compressor running but fridge not cooling
Your defrozed cycle seems to be not working. Means there can be problem with heater , timer or defrzed board or defrozed thermostat. You have to open panel from coil to diagnosed this.
Mar 03, 2014 | GE GSH25JFR Side by Side Refrigerator
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
No Cooling in the Fridge section, freezer is icing
Generally on these models they rely on cold air being pumped fr\om the freezer to the fridge and have a adjusting device to control the flow, you need to locate and check this is free and working properly. Another reason for freezer ice up is a shortage of gas in the unit, this is usually unfixable as the leak can rarely be found as it usually occurs within the cabinet case. Sorry to say it would then be a throw away.
Peter
Jun 03, 2009 | Refrigerators
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty service...Catriver...post back.
Jan 04, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
203 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
