Question about Acer Aspire 3000 Notebook
Acer Aspire 5000 series laptop
Computer was running fine, then just shut off for no reason. (Click noice, and goes black) You could start it back up and it would boot fine, run anywhere from 3 - 10 minutes and then shut off again. Keeps shutting off over and over. that was my main problem. I called tech support, and they told me to do a restore with the disks that came with it. I thought that was a drastic step for a first resort, and I thanked them and hung up. Well after it kept doing it, and I couldn't use, I decided to do the restore. After starting restore it just keeps shutting off, so I can't get through the restore and now it definately won't boot because it had started doing restore and has probablly erased the hard drive, but it won't stay on long enough to get through the rest of the 3 disks. It is plugged in, so can't be battery. Help - computer is only slightly over 1 year old, with minimal usage!
  • Anonymous Nov 17, 2008
    exactly same problem here. ony its on a aspire 5560. bloody annoying.
  • Anonymous Nov 21, 2008
    my problem is with aspire 3004wlci. The fan speeds up and then it shuts down. Doesn't do it all the time. I did re-install everything, didn't help, I tried a cooling pad, didn't work, acer techs last comment was possible video card problem. can anyone tell me how to replace it, or if you have had the same problem and found a solution.
    Problem Solver:
  • 11 Answers
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
Posted on Jul 22, 2010
Kkk
Posted on Aug 06, 2008
If the fan on the processor is indeed spinning, then I would go to your local electronics store and buy some thermal compound. Spread some on the top of the processor and firmly mount the heat sink on top. That should solve your overheating problem.
Posted on Apr 21, 2007
    President:
  • 2,961 Answers
Just check in the power options that anything is not set to shutdown if idle like the hard drive. it sounds really to be processor overheating problem, just check around the side and underside vents for any blockage. Does your fan appear to cut in at any point and stay on or not come on at all, as these things ay be a clue to the problem if it's the processor overheating and shutting down.
Posted on Apr 19, 2007
SOURCE:
Acer 4552 dead screen
hi,
check lcd cable
replaced lcd panel
Apr 06, 2014 | Acer Aspire 4552 Series Laptop Power AC...
HOW TO GET THE BACK OFF
Break it off..........
In order to take the Base Enclosure (Bottom Cover) off, you would have to break it off.
The Acer Aspire 5000 series of Notebook PC's, disassembles from the Top down. When you are done you are looking at an empty Base Enclosure,
http://www.ebay.com/itm/ACER-ASPIRE-3000-3004-ZL5-5000-LAPTOP-BOTTOM-CASE-COVER-LOWER-BASE-3AZL5BATN05-/181127078788
You have to;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Harddrive Compartment Cover, Harddrive, Memory Compartment Cover, Ram Memory, Wireless Module, Wireless Antenna wires out of laptop body, Optical Disk Drive, (DVD drive), Display Assembly, (LCD Module), Keyboard Cover, Keyboard, Palm Rest Cover, Motherboard, and so on..........
Then you have the Base Enclosure. (Bottom Cover)
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Acer Aspire 5000 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 6th line (4920G), scroll across; and click on the blue -> 5000
For additional questions please post in a Comment.
Regards,
joecoolvette
May 02, 2013 | Acer Aspire 5000 Notebook
I have an acer aspire 3000 series and when I turn it on the acer logo shows up on the screen, but after that the screen just goes black.
Hi
If this problem is a recent one and the notebook was working fine
You could try to start up in safe mode then do a system restore back to when you reckon it was ok
Nov 13, 2010 | Acer Aspire 3000 Notebook
Acer aspire 5600awlmi going slow
Assuming stock LT go to start run and type msconfig and click ok. On the general tab select Diagnostic Startup and click ok, it will ask to reboot and seleck ok. After the reboot see if it is operating normally.
If it is working normally then some application is causing the problem. You can selectivly choose to launch one app at a time till you find the one causing the problem. Most likely is antivirus set too agressivley or spyware. Might consider a tool like spybot to clean the system.
Sep 21, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
New fan starts and stops on a rebuilt Aspire 5000
maybe its set from bios to start at a certain temp ...get bios settings to optimal default ...
Aug 01, 2009 | Acer Aspire 5000 Notebook
Acer reinstall issue
Run the same procedure again and choose factory settings. It wd do so , unless the recovery partition got corrupted.
Mar 17, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5600 shut down
it sounds like the video card cannot support or handle the pressure put on it by the game you are trying to play, if it is an OEM game have a look for the minium system requirements that the game will run on, you can also find this information on line, you will probably find out that the graphics card doesn't support the game, do this check with all games you try to play
another thing is to upgrade your memory because some laptops don't have a devoted graphics card thus they are relient on the system memory
good luck
Nov 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5000 series that keeps unexpectly shutting
The hard drives ready for failing, back up everything now to avoid loosing data, run chkdsk /f this command will scan the disk for any problems and try to fix any bad sectors, if this doesn't work i'd think about buying a new hard drive
Nov 13, 2008 | Acer Aspire 5000 Notebook
ACER ASPIRE 3000/5000 SERIES LAPTOP
Log on to your computer with safe mode
Steps
1. Start your computer
2. As soon as you see the first black screen when the computer starts , keep on pressing F8
You will see advanced options menu
Select " Safe mode with net working"
Now your computer will give you an option to log in with the administrator username
You need to log in with Admin and then goto control panel and change the password for your username ...
If this does not work then plz reply back stating the Operating system you have like windows XP, vista , 98 , 2000 etc...
Thanks and dont forget to rate!!!!!!!!
Jun 04, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
944 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
