Question about Kenmore 24032\24036 Top Load Washer
No spinning or agitating
My kenmore top loader will fill with water, will drain the water but it isn't spinning or agitating. Help!?
  • lisayoung434 Dec 26, 2008
    Does that mean the switch needs replaced or is there something I can do?
If it has a mechanical timer switch, (the main control knob) that is possibly the culprit. The timer switch is basically the "brain" of this type of washer. I had this problem on a washer.
Posted on Dec 26, 2008
  • volksman33 Dec 27, 2008
    If it is the switch, you might be able to replace the faulty part in it, some of them are modular. It actually is not as difficult as it might seem. Unplug the machine and look at the electronics enclosure carefully. You will find a series of smallish screws that will grant you access to the interior of the enclosure. Examine the switch for burned contacts, loose wires, anything that looks like it might be out of the ordinary. If you do have to replace it, search the WWW and find it cheaper than from a shop. Call your local appliance repair shop and quiz the techs or the parts guy, they are, in general, very friendly and helpful
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Kenmore will not agitate
The timer is the most common problem. Call any appliance parts store and tell them the model number and ask for price for new timer. Also call sears appliance parts and get price. But a new timer and install it.
Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE 90
There is a part between the motor and gearcase called a coupler, the clicking happens when it cracks. Easy way is to pull the machine foreward and tilt it back to expose the bottom. Clips hold a pump, has two hoses attached, then a motor, unclip wire harness on left and any other attached, mark these extra wires if it has them. The motor has two clips supported with two 1/4 in hex screws, Now you should see the coupler, a rubber donut and two three pronged plastic flanges attached at gearcase and motor. Use a 1/2 socket to flush the new coupler flanges on both sides and the rest is a experience.
Aug 25, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
107 people viewed this question
Sal De
fordexpert
Robert Rankin
