Question about Toshiba (SD-M1212) Internal DVD Drive
HI THERE HL-DT-STDVDRAM GMA-4082N ATA DEVICE
HL-DT-STDVDRAM GMA-4082N ATA DEVICE THIS IS MY TOSHIBA LABTOP CD ROOM SRIVE AND IT FAILS TO WORK I CHECHED IT ON ON DEVICE MANAGER BUT IT SAY THE UR DRIVE IS CORRUPTED OR MISSED THANKS
  • vcapriles Mar 05, 2009
    my laptop lenovo 3000 n200 uses a HL-DT-STDVDRAM GMA-4082N ATA DEVICE and suddenly it doesn`t work anymore, it reports an error code39 and I need your help
Nitrotrike
  • 589 Answers
SOURCE: GMA 4082n device driver not working properly code 39
Please post the exact model of the notebook, as there are several models in the A60 series.
Posted on Jan 09, 2008
worldvet
  • 859 Answers
Thank you for using Fixya.com and glad to hear to got your monies worth.
Regarrds,
Worldvet
Posted on Jun 09, 2008
untameddevil
  • 10 Answers
http://support.microsoft.com/kb/314060
Try this article...............hope it should work otherwise would suggest something lese as well......All the best....TC
Posted on Jul 20, 2008
hardkiss69
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
I had the same problem with the HL-DT-ST DVDRAM GMA-4082N on a Toshiba laptop.
There is a solution here: http://sillydog.org/forum/sdt_9200.php. Recommend when you delete from your registry to make an exact note of what you deleted so that you can roll-back to what you had before just in case anything goes wrong.
The first time I rebooted when I opened "My Computer" my laptop was unresponsive but on rebooting for a second time the drive was back working and everything seems fine again.
Posted on Dec 01, 2008
HL-DT-ST DVDRAM GMA-4082N ATA DRIVER DEVICE Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) My cd/dvd drive stopped working. it says that the...
backup whatever information you have and run the system recovery through the disks you received when you purchased the computer. If you can perform the recovery then you know the hardware is fine and that you were experiencing software corruption.
Nov 16, 2009 | Toshiba Satellite A135 Notebook
The dvd does not need driver, you need to reinstall Windows.
Jul 18, 2008 | Toshiba Satellite A135 Notebook
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
this is due to the fault of the device you should replace it
Oct 02, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
check whether the device is detecting properly on bios or not
Oct 01, 2008 | Computers & Internet
Not work
Try this...
It should clear out error code 10
hope this helps...
Jul 25, 2008 | Toshiba Satellite A135 Notebook
Jul 20, 2008 | Toshiba Satellite P105-S6104 Notebook
Regarrds,
Worldvet
Jun 08, 2008 | Toshiba Satellite P100 Notebook
Go back to the device in device manager, right click on it and select properties, then under the driver tab click on "Roll back driver" button and see if that does the trick.
May 07, 2008 | Toshiba Satellite P100 Notebook
sounds like your cd/dvd is mechanically shot. time for a new one.
Mar 09, 2008 | Lenovo 3000 C200 Notebook
Toshiba (SD-M1212) Internal DVD Drive Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
