Question about Brother IntelliFAX 1270E Plain Paper Fax
Paper Jam message
My fax machine sends a message stating that there is a paper jam, even though there is no paper in the machine. Subsequently the machine doesn't work because of this.
  • kottayam Jan 07, 2008
    we've checked all possible places, there is no paper, faxes are transmitted ok, but we can't get receipts.
  • 328 Answers
There are a couple of sensor flags in side the machine and also the document feeder area. Little black levers that flip and trip a sensor. Make sure they are all moving freely. There is one or two in the doc feed area. One inside the paper feed area. One or two in the ribbon area.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 09, 2007
SOURCE:
Why am i getting the error message * memory rx 2P Recording Paper Jam? I can t find a jam anywhere?
Delete the fax and check paper tray rollers are cleaned. May be missing feeding which mean roller can't grab the paper and machine is expecting the paper to be at a certain point and does not see (Though sensors though out the paper route thru the machine so it thinks there is a paper jam) Also mite want o clear the memory (SRAM/DRAM) will lose one touches so make sure you have list backup
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 27, 2014 | MinoltaFax 2600 Printer
Paper jam won't go away and its no paper in the machine
was there a paper jam in the first place where you had to pull the paper out?if so try and get in there and check if there is a little peice left as i believe these have little sensors that are affected very easily by the tinyest of paper. good luck!
Feb 07, 2012 | Sharp UX 355L Plain Paper Thermal transfer...
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Message shows paper jam even though there is no jam
take all the paper out make sure there is no dirt or dust in the corners,then unplugg the machine for 30 sec. power back up and reload the paper
Feb 26, 2009 | Office Equipment & Supplies
Paper Jam
did you open the rear door and check in the fuser?
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxing
Hi:
You may have removed the paper but the reason why it is still saying paper jam can be caused by at least two things.
If you removed the paper, but it tore while you were taking it out then a small piece could be blocking a sensor or a sensor flag ( a spring loaded finger that the paper has to activate as it moves through the machine) It's possible that a small piece of paper could be blocking a sensor or you may have disloged one of these 'flags' in the area where you first removed the paper. Go back and look closely in that area for a piece of paper or a sticking ''flag'. Until you do that the fax keeps thinking that there is something in the paper path and will keep displaying that message.
Andrew
Jul 20, 2008 | Brother FAX-575 Plain Paper Thermal
Paper jam, and check film error messages
dear sir the film sensing sensor and paper path sensors are abnormal or dusty pleaz check them
Sep 19, 2007 | Panasonic KX-FP121 Plain Paper Thermal Fax
Paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Feb 04, 2007 | Canon Image Runner 1630 Copier Copier
Jammed document
JC
I had the same problem- jam error with no paper in it. I tried all of the suggestions to no avail. So as a last resort before I went and purchased another one I unplugged it, picked it up, turned it upside down and whacked it a few times. To my surprise when I plugged it back up it worked just fine! Haven"t had any problem since. I don"t reccomend this but as a last resort, what the heck!
Jan 30, 2007 | HP 1040 Plain Paper Inkjet Fax
Brother IntelliFAX 1270E Plain Paper Fax Logo
154 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
