Question about LG CU500 Cellular Phone
Cannot hear ringing tone or voices
When I try to dial out I cannot hear the phone ringing the other person and when I receive incoming calls I cannot hear the person on the other end
  • Anonymous Mar 06, 2009
    same here
    I can hear myself dialing a number but cannot hear the phone ring nor a conversation on my bluetooth
  • Anonymous Mar 16, 2014
    canot ring out no dial tone very noisey home phone
  • 22 Answers
Its the problem with the speaker... Change it...
Posted on Dec 27, 2008
My phone #1 does not ring nor can I get a dial tone.
Troubleshooting Home Phone for No Dial Tone ' iiHelp
https://iihelp.iinet.net.au/Troubleshooting_Home_Phone_for_No_Dial_T...
This article will explain what to do if you can't make or receive calls using your HomePhone (landline). ... If it rings normally, skip to step 3. If you hear an engaged tone ora recorded voice saying the number is not available, ... If you have a dial tone and can make a call when your phone is plugged into one socket but not ...
No Dial Tone - Phone Forum - Phone Forum - Cox Support Forumsforums.cox.com/forum_home/phone_forum/f/6/t/3496.aspxJan 1, 2014 - 16 posts - ‎13 authorsThis will help determine which phone or jack may be contributing to the problem. If these steps do not restore your phone service it may be necessary to ... directly to the #1 telephone port on the modem and see if you get dial tone there. ... Then try calling yourself(from a cell phone), and as it rings, plug the ...Big Mystery...Phone won't ring ' Techlore
Jan 10, 2016 | Lands Phones
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
Have setup in this order dsl modem,dir615 router,spa2102 phone adapter,get dial tone,hear ringing when making or receiving calls but no voice,what gives??
incoming voice ports are not open on the router. the devioce uses one IP port to set up the call (ringing) and at least 2 others for audio. read the manual I'm afraid.
Nov 06, 2009 | Computers & Internet
BlackBerry Pearl 8130 - no ring tone on incoming calls, can only receive text and voice mail
In your BlackBerry Pearl 8130 handheld go to Profile and then select Advanced, Highlight any one the profile then click on menu key and then select Edit and then select Phone, Then select Out of holster, Press menu key select the tone. You will be able to hear the tone for incoming call.
Oct 18, 2009 | RIM BlackBerry 8700c Cellular Phone
No voice received on incoming calls
try useing it on speaker phone..if it works there then the problem is in the speaker..it is eeasaly replaced also you can try and do a software upgrade..
Oct 07, 2009 | Motorola Mobility RAZR V3x Cellular Phone
No dial tone - phone rings for incomming call but I can't hear or talk
This can be a problem with your handset.
Have you tried a different phone in that same jack?
Apr 17, 2009 | Lands Phones
Can't dial out or receive calls
constant dial tone and cant dial out or receive calls
Feb 24, 2009 | Uniden Cordless Phone
Unable to dial out, check voice mail and see call display
Hi at the back of the phone you will see a selectable Hi/Lo/Off switch. Slide the (Ringer) switch to High position or Low position to turn the ringer on. Hi for high volume Lo for low volume.
To prevent hearing any ringing of incoming calls slide the (ringer) switch to the off position but when you ready to accept incoming calls again remember to slide the switch back to either Hi or Low setting. Hope this made sense and helped.
Oct 24, 2007 | Curtis Trimline TID582 Corded Phone
LG CU500 Cellular Phone Logo
484 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
