Question about GE MiniCam Pro HO98756 Webcam
I plugged in the cam before i installed everything?
    Problem Solver:
I'm not 100% sure his will work, but try using the CD that came with it and uninstall the program, and start over again. Please let me know if this works for you.
Posted on Dec 27, 2008
I have a 2002 nissan sentra ser spec v. my car wont start, im not sure if its a timing issue. i had changed the head gasket and when putting everything back i installed new cams. i pulled a plug out and...
The coils are fired from the OBD box. If you changed the cams, make sure the pickup timing marks on the new cams are the same as on your old cams. The OBD reads the position of the cams from a sensor, which picks up the cam position from the cams themselves. If there is no signal, or a faulty signal from the cam sensor, the OBD will not fire.
Aug 29, 2017 | 2002 Nissan Sentra
I have a web cam i bought about a week ago i misplaced the installation cd is it possible to install it without the cd ???
If your windows does not recolonize it alone or the website does not have the driver i would call and ask for a new cd. Those are really about your only options. Hope everything works out for the best my friend
Jun 25, 2010 | Computers & Internet
I can't find the timing marks on the pulleys, the cilinder heads and the cilinder block.
it doesn't have any. there are no keyways to line up. you need a speacial plug that the crank shaft rests against and ther is a flat tool that fits into slots on the back side of the cams (you have to take the high pressure fuel pump off). if you loosen any of the cam bolts or crank bolt without them everything is out of time. why do you need timming marks, you don't have to change the chain. are you installing a new vct gear?
Apr 17, 2009 | 2007 Mazda CX-7 Grand Touring
Microsoft lifecam VX-6000 - no Video
your cam has to be setup with the messaging programs have you tried that
and does your cam show in device manager
Feb 01, 2009 | Microsoft LifeCam VX-6000 Webcam
DVD Driver Failed to load after installing Pleomax PWC-3800
uninstall the cam from device manager
unplug the cam reinstall with software don't plug the cam in till asked
also read everything carefully make sure your installing it to c:/
program files
Jan 12, 2009 | Samsung Pleomax PKB-7000X
I need help installing software for my creative web cam
Put in the cd that came with the webcam. Do not plug in your web cam until the software asks you to do so. Follow the on screen instructions and you should have everything running smoothly.
Jan 12, 2009 | Creative Labs WebCam Live!
Vupoint FS-C1-VP scanner installed
i have vista home and mine worked fine until i installed a web cam and then it just gave up. But now it works great - here is what i did
unpluged both the scanner and the web cam
uninstalled everything to to w/ the scanner and the web cam.
Installed the driver from the CD and restarted my machine
Install the Photo 6 software
plug in the scanner - works like a champ.
have not reinstalled the web cam
Oct 02, 2008 | Office Equipment & Supplies
Problem
Same problem. Have Creative Web Cam Pro. When I installed it and everything it showed me sitting there and I could see myself fine. I open PC-CAM Center, however, and it says "Creative Camera not detected. Please plug in to continue..." It's plugged in. I can click the button on top and the PC-CAM center comes up, so I know it works. But it won't detect it. Thanks for any help you can provide!
Dec 25, 2007 | Creative Labs WebCam PRO
Won't work at all
uninstall everything. unplug the cam. restart. put cd in. run the auto run and it will install the drivers and program for the cam. after its done take the cd out. plug in your cam. the PnP will find it and automatically update the drivers and recognize the cam. it should work then.
Dec 11, 2007 | Philips J44414
Message: cam not detected
look for cam cable loose connection, or the cable itself is bad!( it's the common problem, check the cable end tips!) uninstalling, installing and reinstalling any software and driver is useless too. The pc must recognize first your webcam, if the connection is not good theres no way it can be detected by the pc.
Sep 12, 2005 | Creative Labs PC-Cam 600 Digital Camera
GE MiniCam Pro HO98756 Webcam Logo
18 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
