Question about Dell Inspiron 8500 Notebook
Cmos battery dead - needs to be replaced
Please advise how to replace the cmos battery, as I presume it is dead as each boot of DELL Inspiron 8500 defaults to date in 2003
Also loses power adapter type and asks to hit F1 to continue,
regards
ted
PS Its main battery has been dead (and removed for years) snd I run only on mains power via the original supplied power adapter.
  • zetordog Dec 27, 2008
    I know battery needs replacing - where is it on the del pc??
    HOW do I replace it?
    rgds
    zetordog
  • zetordog Dec 28, 2008
    Guys,
    Great responsive service.
    I appreciate your efforts - keep up the good work..... God knows we need it in the world we live in today.
    zetordog
  • 51 Answers
Sounds like you need to change the CMOS battery, the time being wrong everytime you boot is a good sign but also it losing its settings in bios is also another sign
Posted on Dec 26, 2008
  • Christopher Sherwood
    Christopher Sherwood Dec 27, 2008
    What seems annoying is that the battery is not a normal watch battery, there or several put together so it will have to be ordered for dell themselves. here is what the battery looks like
    The battery will be connected directly to the motherboard so you may have to take the notebooks case completely off to get to it if it is not reachable from the underside of the notebook.
    contact DELL Support as they will be able to help you fix this problem and should be able to order a new part for you.
    Click her for the DELL Contact page
    Christopher Sherwood Dec 28, 2008
    No problem, anytime
Replaced the battery in my inspiron 531. first I got two beeps when I tried to boot up. I shut everything down and next I got a dell screen no blinking cursor and a dead keyboard. disconnected all usb and...
Why did you replace the battery ?. You may need to do a CMOS reset/clear and there maybe a jumper on the board. If not turn the power off at the mains and remove the battery for 5 mins then refit and power up with keyboard and monitor connected enter the BIOS and set date and time save and reboot.
Jan 15, 2014 | Dell Inspiron 531s Desktop Computer
Inspiron 1000 doesn't save cmos settings
Hi
As you said that you haven't used the computer for long time then it could be the motherboard which has gone faulty not the HDD or DVD.
Try to use the new HDD with this old motherboard.
Or else you can seek help of Any Geek Squad or computer vendor.
In case if you have any more trouble do contact back in Fixya.
Thank you
Sep 05, 2012 | Dell Inspiron 1000 Notebook
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Dell inspiron 530 cmos checksum
This error usually occurs when the CMOS/BIOS battery is flat.
Replace the BIOS battery and then boot up and go into the BIOS setting to setup the Date & Time etc.
Jan 30, 2012 | Dell Inspiron 530 Desktop Computer
My dell inspiron 8500 wont start up whit the battery
if it is the original battery, it most likely needs replacement. Portable batteries have a expected life of 300 to 500 recharge cycles (18 to 24 mos) If a new battery does not charge, then a motherboard replacement is warranted.
Oct 01, 2009 | Dell Inspiron 8500 Notebook
Need to unlock bios password on dell laptop, have service tag # and ends in 59b
If you have loast the password, to reset the BIOS password you need to remove temporarily the CMOS battery , so to reset BIOS settings.
Some model may be using NV Ram, in that case removing the battery is not enough.
The battery is located on the lower side on the motherboard.
On many DELL models the battery can be accessed from the side of DVD slot, battery slot, or RAM slot, without disassemblying the laptop.
On some model you may need complete disassembly (eg. Dell Le series).
The battery looks like a couple of coin batteries wrapped in plastic.
Before disassemblying or removing covers, always unplug adapter and remove battery.
On Dell Inspiron 8500 the battery can be accessed from a side , after removing the primary battery.
I think Dell 8500 can be set to use NV Ram to store the password.
In this case the problem cannot be solved removing primary battery, then accessing and removing CMOS battery for few minutes.
If you still cannot reset you have two way out.
Disassemble completely and access the NVRAM microswitch, or contact Dell and get master password.
You can also try one of this standard Dell factory CMOS password:
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
Dell
Sep 11, 2009 | Dell Inspiron 8500 Notebook
Dell Inspiron 8500 doesnt continue boot up
is the crackling noise constant?
if so, your hard drive is lockup on the bootup. you have to get a new hard drive.
or you can try to reformat the hard drive, but I don't think that will help.
Jan 03, 2009 | Dell Inspiron 8500 Notebook
Dell Inspiron 8500 - Screen stays lit on initial boot
from what you describe its a video problem i dont remember if those have on board video if so you will need a mother board
Dec 07, 2007 | Dell Inspiron 8500 Notebook
Open Questions:
Dell Inspiron 8500 Notebook Logo
405 people viewed this question
Alun Cox
