Question about IBM NetVista PC Desktop
Ram upgrade problems IBM netvista 6794
I recently purchased (3) 512mb hd chips to upgrade my IBM nrtvista 6794 (k7u) which has the slots for ram. I've tried everything possible to get it to accept all three but it wont it upgrades to 1gb just fine but when i shut down and add the 3rd it hangs up and kicks to the set up utility screen. with no aveil. then shut it down and remove one stick and it does the same thing but comes up with a memory size error????? only way to fix is to shut down and install the original 256mb ram card then restart/shutdown/ install 2x 512mb and i'm fine.....???? I've looked all over the internet and can find nothing as far as answers plz help.........thx
  • xpok7 May 11, 2010
    Can you specify exactly what RAM chips they are, and their speed? A link would be preferable.
    Sergeant:
    Champion:
  • 233 Answers
You can try this site, it scans your system to see if your computer can run more memory than what is currently installed. it helps you find the right memory modules for your system and and an option for you to read reviews if available and if you want to buy it.
try this site: www.crucial.com
Please rate this solution
Posted on Dec 28, 2008
I have an IBM NetVista PC model #830781U and want to install additional memory...1GB chip... How do I do it??
Ok, first of all before installing the ram, you want to make sure the ram you are installing into your computer if the motherboard support the type of ram chip you are installing it in. For your model it is ddr184 pin After this, you can take out your case panel which is the left side by unscrewing the 2 screws in the backside of the panel. Carefully take the panel apart from the computer and set it aside. What you want to located is the RAM slot on your motherboard which typically is 2 slot next to the cpu which has the big fan. Most likely one of the slot or both of the slot is already accompanied by the old memory chip. There are two hinges one on each side, bottom and top. Push these pins down and it would loosen up the memory chip that is already installed on. Replace the new memory chip and make sure you align the golden tooth pins extacly to the memory socket and then push down on the chip until it clicks. Test your computer if it works, if not. You computer may not support the memory chip.
Jan 13, 2011 | IBM NetVista PC Desktop
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
Problems with 3 brand new PC 133 512 MB RAM in Netvista 6794
That last RAM probably is good. Many motherboards have problems using many different memory. All of the memory you have should be at least identical to ensure that they work. When RAM run at different speed or require a little more voltage, they will not let your motherboard boot. You can try mixing up the order you put the RAM in. Try putting the last RAM in the first slot by itself, the motherboard should boot. Then try the rest.
Also, whenever you add or change hardwares, you should clear the CMOS/BIOS settings.
Jan 06, 2010 | IBM (49P1599) Motherboard
Will ibm rev1.6 motherboard will support DDR2 RAM ??????
Check the RAM slots -- in the "channel", there are small vertical "blocks", so that only *ONE* type of RAM (SDRAM, DDR1, DDR2, DDR3) will match-up the "slots" amidst the gold pins on the RAM.
Given that it's a ThinkCentre/NetVista motherboard at 400 Mhz:
http://www.shopping.com/xPO-IBM-SYSTEM-BOARD-W-O-POV-02R4087
with a Pentium 4 CPU, it's very-likely that it _only_ supports DDR1 RAM -- it's simply too old to support DDR2.
Dec 05, 2009 | IBM (02R4087) Motherboard
Can i install windows vista ultimate in ibm netvista 8303 with 768 MB Ram, 64 Graphic Card and 2.0 GHz Procesor?
it will surely install but it will be very slow in the operation because your system does not meets the minimum requirements you will have to upgrade your ram and graphics card to run it optimally
also
some programs you use will also run slowly
so reccomend you
vista home basic
or
xp sp3
additionally you can insrtall various customization packs to enhance the xp gui
Jul 11, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
I went and bought new ram for my computer. it's an IBM desktop. type 6792. a pc133 512MB sdram. my computer will not pick it up. how do i get the computer to pick up the ram? it is the right kind of ram?
I checked at http://www.buffalotech.com/products/memory/select/select-dimm/ and according the the memory configurator there your IBM Netvista 6792 takes this type of memory which can be ordered from them PC-133mhz SDRAM DIMM 168 pin, it indicated that your pc has 3 slots for memory and the maximum size you can put in each slot is 512 MB which would give you the maximum memory of 1536 MB. I have had problems in the past when replacing memory in IBM PC's some modules won't work because IBM uses different memory than other Manufacturers. But give Buffalo a try, their memory is guaranteed.
Apr 05, 2009 | IBM NetVista PC Desktop
Ibm netvista 6794 ram upgrade problems
CL- pc13 memory is reccomended. 512k memory sticks of the pc133 variety give a lot of users problems, you have to find a specific type of memory when installing 512k chips. to get all 3 to work, i sugfgest using 3 sticks of the exact same type (same memory modules on each stick)
Dec 27, 2008 | Computers & Internet
Memory upgrade
no jumper just touchy mobo on ram u buy u have to buy ram off ebayt samsung low denstity 64x64 chip config ok like i did and it workeed mark this as fixed ya so others can get same help thx nick
Jan 30, 2008 | IBM NetVista M42 PC Desktop
IBM NetVista A40 Memory Upgrade
It would be advisable to go to the IBM website and then to their support link, find the manual for your system and see what it says about memory upgrade of your system BPCS
Dec 28, 2007 | IBM NetVista A40 PC Desktop
IBM NetVista PC Desktop Logo
240 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
