No picture on Packard Bell LCD TV 170ASW
I bought a Packard Bell LCD TV 170ASW from a friend and the unit came without a power supply. I finally managed to locate one but the plug needed changing. The kind assistant offered to change it for me as I do not have a multi meter at home. Unfortunately he made the plug centre negative instead of positive and I did plug the power supply in and attempt to power the unit up. I immediately realised that something was wrong and turned the power off. The unit seems to be working fine apart from the fact that there is no picture at all. The sound is fine and all other features seems perfectly ok. I opened the unit up and can see that the solder on the socket is discoloured but also noticed a 7A fuse next to the socket. Is there any chance off the unit being repairable?
    Problem Solver:
  • 10 Answers
Hi there , dont no if this is any help , i have the same model that would display an image when its in setup mode but as soon as you choose tv or computer it would go blank with just sound , did not find the exact fault there s a small short to do with the backlight board , but when i remove the backlight connector from the main pcb and remove the yellow ? wire from the connector the one on the xtal side of the connector and refitted the connector with out the yellow wire the tv worked fine .
Posted on Jun 30, 2009
Bought a Packard Bell Onetwo L5851 yesterday. Unable to switch it on....Blank screen with a few lights below,thats it . Nothing responding.
I have a similar problem with a Packard Bell OneTwo S PG4G1TU01 : when switching it on, it work a few minutes and suddenly shutdown, as a brutal power down. But the green light at the bottom still working. I have changed the extern power supply and now it work fine... The new power supply is a 90W model, not a 65W like the original one. Maybe it can help ?
Dec 28, 2010 | Computers & Internet
My power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
http://www.partstore.com/GetModel.aspx?MfgName=Sumitomo+Group&BrandName=Packard+Bell&ModelNumber=845061&Page=1&SortBy=idealitemnumber&SortDirection=desc
Apr 23, 2010 | Packard Bell (190169) Power Supply
Where can i buy a psu..(fsp250-60hen) for my packard bell desk top
Take your current power-supply to any computer-store, so that they can match its size, and its connectors (both the number of connectors and the shape of the connectors), with a replacement power-supply unit.
Apr 16, 2010 | Packard Bell (190169) Power Supply
Need to order a power cord for a packard bell pentium II
The power cords for desktop computers are standard items. You can purchase one from your friendly computer shop.
Oct 07, 2009 | Packard Bell Pentium II, 266 MHz Cyrix MII...
Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
May 11, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
PACKARD BELL AND SAMSUNG TV
Many Packard-Bell systems use a Crystal sound card.
If you can read the number from the sound card (usually CSXXXX), you can pick the exact driver from this site:
http://drivers.myfreewares.com/vendordrivers-7-217-crystal-semiconductors-soundcard-download.html
Oct 16, 2008 | Packard Bell (030069) Sound Card
Packard bell power supply
The motherboards short out when the box goes out most of the time, you should get a new power box, and a motherbaord.
Dec 28, 2007 | Packard Bell (190169) Power Supply
Packard bell imedia 1308 power supply unit
Do you have the correct/original power supply, and it is having problems of some sort? If so, you might be able to do some repairs. A common problem is often one or more of the electrolytic capacitors is bad. Take the cover off, and look for bulged capacitors (top of the capacitor pushed up & out). If you find one or more of these, replacement may return the p/s to working order.
Please note in ATX power supplies, you have a standby and full power or main section. The standby portion powers just a small section of the motherboard to sense when the power button is pushed, and activate the main full power section. Obviously, the main section powers the full motherboard, drives, fans, etc.
I've seen several units where the standby section has one or more bad capacitors which will produce either a dead or slow to turn on computer.
Use a voltmeter and monitor the voltages. There are sites on the 'net with pinouts http://pinouts.ru/
Check here for further instructions http://www.fonerbooks.com/power.htm
As regards replacement capacitors: I use mostly the Panasonic FC series available from Digi-Key Electronics. Mouser Electronics also has suitable units. You want capacitors designed for switching power supplies.
Hope this helps you out.
Nov 18, 2007 | Work Station 250W ATX POWER SUPPLY (=...
Televison & Video Logo
435 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
