Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Linksys router causing tv interference
I just set up my wireless linksys router and the tvs in my house will blurr for a couple seconds every minute. Why is this happening? Any way to fix it?
    Novelist:
  • 115 Answers
Apparently, your router is working at a frequency too close to your TV's incoming signal. You can try changing the channel (frequency) that your wireless operates on. Click this link for Linksys' troubleshooting wizard, which will show you how to do this.
If this doesn't help, you might return your router for a different model (I only use belkin myself).
Posted on Dec 26, 2008
After 3 years with the Linksys wireless G broadband router and excellent strength, the last 3 days my wireless router is producing a very low signal....why?
Sometimes, new interference from devices unknown to you cause the problem. Additions of a new microwave, cell phone or even faulty wiring in the house can output electrical interference.
But it is not uncommon for the Linksys routers radio to fail as well.
Consider replacing it with a newer Linksys router that will be compatible with docsis3 speeds and above.
Jun 17, 2011 | Linksys Wireless-G Broadband Router
Loosing internet connection every 15 minutes
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Linksys WRT120N Router
Hello, i have recently got some turtle beach x 31s and they are great but my xbox connection keeps going. it will work again after a few minutes but then it will disconnect again. i have read that there...
This pertains to Linksys routers, but it applies to all routers
To change the router's SSID or the wireless network's name,
To change the router's channel, .
To enable the wireless security on the router, .
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router's firmware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Dec 30, 2010 | Computers & Internet
The router often looses wi-fi signal and dhcp gives wrong address ( exemple: 169.164.....)
Here are some links for things to look for and check for you wireless connection isues:
If the links do not work just copy and past them in to you browser. If you dont have a internet connection available I have listed them below the links.
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=172c1dae41534ddd818c560b60c7c230_4029.xml&pid=96&slnid=16
http://www6.nohold.net/Cisco2/ukp.aspx?vw=1&docid=efc03a44a5bb47bd804cf4d0eb3015c8_Top_Causes_of_Intermittent_Wireless_Connection_to_a_Linksys_.xml&pid=96&slnid=16
Top Causes of Intermittent Wireless Connection to a Linksys Router
There are three key reasons that may be cited why the wireless connection between your Linksys router and your computer is intermittent or is experiencing timeouts.
i. You have a low signal quality received from your wireless router.
ii. You are experiencing signal interference from other wireless devices.
iii. Your router's firmware needs to be upgraded.
You have a low signal quality received from your Linksys wireless router.
The location of your wireless router with respect to your computer greatly influences your connection to the wireless network. For a better signal quality, it is ideal that the wireless router is placed in a central spot of your house or on a location free from any obstruction blocking its range.
To determine the signal quality received from your wireless router, you must connect to the wireless network first.
NOTE: For instructions on how to connect wirelessly to your Linksys router, click here. If you're using a Mac computer, click here.
Once connected, check the signal strength received by your wireless adapter or Airport for Mac users. The recommended signal strength should be closest to full bars to have the best connection possible.
The frequency used by your router's wireless network may be 2.4 GHz, 5GHz or both. Some devices may also be using the same frequency and this causes the interference to the wireless network of your Linksys router. The most common examples are cordless phones, microwave ovens and baby monitors. Another possibility of frequency interference is that there may be other wireless networks in the area. Your frequencies may be conflicting with each other.
To solve this, turn off the device that is possibly causing the interference or relocate your router away from it. Another solution is to change the current wireless network channel which is set in your router's settings. For instructions on how to do this, click here.
If you are having unstable connection and have confirmed that the previous causes are irrelevant, then you may have to upgrade your Linksys router's firmware. For instructions on how to do this, click here.
Encountering Intermittent Wireless Connections Using a Router
Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
  • 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors'), or other nearby equipment. Try to change your router's channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
  • Customizing Wireless Settings of the Router
    Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. We suggest changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
    1)To change the router's SSID or the wireless network's name, click here.
    2)To change the router's channel, click here.
    3)To enable the wireless security on the router, click here.
    NOTE: If the wireless connection remains unstable after performing the steps above, it could mean that your firmware is corrupted. For instructions to reload or upgrade firmware, click here.
Dec 14, 2010 | Linksys WRT120N Router
I get limeted access to internet
To change the router's SSID or the wireless network's name, To change the router's channel, To enable the wireless security on the router, Log ionto your router, 192.168.1.1
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router's firmware on Linksys
Dec 08, 2010 | Linksys Wireless-G WRT54G Router
My wireless is going on and off, what's the problem?
• Wireless interference within the network
• Wireless settings of the Linksys ADSL gateway are still set to default
• Firmware is corrupted
NOTE: Before going through the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
To resolve intermittent wireless connection, you need to perform the following steps:
i. Reducing Wireless Interference
ii. Customizing Wireless Settings of the ADSL Gateway
Nov 11, 2010 | Linksys Wireless-G WRT54G Router
Wireless Connection Conflict
I would enable/disable your mac address clone. Do the opposite of what ever the setting is. You should be able to the setting on the main setup page. If it does not fix it, change it back. I know that can cause a connection to quit working if the setting is not correct.
Jul 19, 2010 | Linksys Computers & Internet
Why does the linksys wireless router ''WirelessG: keep going off/
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Apr 05, 2009 | Computers & Internet
Continuously lose connection
For the Firmware update go to :www.linksys.com
Thanks, Joe
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
I can't stay connect on-line
  • 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Thanks, Joe
Nov 25, 2008 | Linksys Wireless-G WRT54GS Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
143 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
