Question about Maytag Performa PAV2200
Maytag performs washing machine
I tried to wash two rugs. they came apart and twisted under the agaitor( not sure if I spelled that right). Anyway I need to unloose the material, how do I take off the agaritor? I tried to turn the fabric softner dispenser both ways, but I couldn't get it turn loose either way.
Thank you, Mona
  • 179 Answers
You need to tilt the dispenser to one side then it will pop off once you get that off you need a socket set to remove the bolt from the center of the agitator after removing the bolt the agitator just lifts up
Posted on Dec 26, 2008
I overloaded my washer and the red lock light is flashing and won't reset or wash now.
Marilyn,
Sounds like you will need to perform a master reset. Here is a link that will guide you thru: How To Fix Washing Machine That Is Not Spinning or Draining
If you need further help, reach me via phone at https://www.6ya.com/expert/timothy_c6f309c0f75b6f43
Jul 14, 2014 | Maytag Bravos X Series MVWX500XW
The washing machine will start turn a few times add some water but then stops and the light flashes
Sounds like unbalanced now - try to rebalance the adjustable knobs under the washer - we have to rebalance every few months because our floor isn't the straightest. We always know when its time because the washer won't work right.
Mar 23, 2014 | Amana NFW7300WW Washer
Maytag performance top load washer
follow this steps and fix it. God bless you
  1. No power to the washerMake sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
  2. Lid switchThe washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Read more: http://www.appliancepartspros.com/repair-help/washer-repair-help.html#1#ixzz2YbiV2et5
Jul 09, 2013 | Washing Machines
Washing machine won't drain. I had washed an old throw rug and there is still water in the tub.
There is a coin trap in the pump most likely is pluged // u have one machine that is very hard to write down how to take apart as you have to remove the door lift top remove front panal .. pump is on the lower right ..I would leave that one to a pro if you never done one before......good luck
Feb 01, 2011 | Maytag Neptune MAH5500B Front Load Washer
Throw rugs are dripping wet after washing. My washer doesn't have just a spin cycle, so I have to rinse and spin. This still doesn't help. Every rug I wash comes out dripping.
The washer is likely detecting an off balance load with only a rug or two. You may want to try and put more rugs or old towles in to offer a counter balance to alleviate off balance condition. Or, you may consider washing the rugs at a commercial facility. They really are hard on the residential machines, especially if they come apart or the backing comes off.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
MY FISHER & PAYKEL WASHER STOPPED AFTER RINSE WHEN I WASHED BATH RUGS THAT FELL APART. IT WON'T DRAIN AND MAKES A WHINING NOISE WEN ADVANCED TO SPIN CYCLE. WHAT SHOULD I DO?
Your pump is blocked with the bits from your wash. A handyman may be able to service the pump, but it would be a quick job for a tech. The pump us accessed from under the machine and can be inclipped like a light bulb. Inspect carefully first. look for small latch clip before twisting. Make sure the machine has been bailed out first. lean the machine back againt the wall to give access and to keep what little water remains, away from the drain/pump hole. Good luck....Nomess
Jul 13, 2010 | Fisher and Paykel Washing Machines
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
WASHED RUG IN MY NEPTUNE WASHER. rUG CAME APART. washer won't drain all the way. ND COMES UP.RUG WAS SHAG TYPE.hELP!
You will have to clean up drain system in washer. Get the rug pars out. A wet vac is a useful tool here.
May 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Frontloader (Perf series) brand new Agitator off axis
Okay! We just fixed this problem on our washer. First, be safe and be sure that the electrical cord is unplugged. Then you want to take the lid panel off of your washer. Then you'll feel around under the base of the agitator/washer basket. You should notice that its feet sit inside huge springs which are fixed to the base of the machine unit. Determine whether any of your basket feet are disloged from their spring and re-insert. Make sure the fit is good or else you might have the same problem again. After you reassemble, plug in the machine and try a test spin without any clothes. Then try with a smallish load.
Hopefully this helps.
Jan 04, 2009 | Maytag Neptune MAH6700A Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
