Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Lexicon Lambda on Mac
Only records through the built in mic on the mac not through the Lambda and don't know where to look to fix the problem... HELP Was better off with the old 32 track but was talked into this nightmare!!
  • ironfrown Apr 04, 2009
    Yes, having the same problem. Any solution?
    Jacob
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Posted on Jun 14, 2009
I installed the lexicon lambda with the disk provided but when i put my mic on the mic input it doesn't record... what should i do? please help!
first thing to do is check your sound and audio settings, goto control pannel,then, sound/audio setings and see if everythings set up properly
Sep 19, 2011 | Lexicon Lambda Usb Desktop Recording...
Have just purchased lexicon alpha to use on a Mac. Having trouble just getting started. Have hooked up a nice condenser mic into the alpha through the mic input on the rear and cannot get anything on the...
Make sure you have Phantom power turned on on the Lexicon... Oh,oh... it appears that the Alphs may NOT have phantom power which IS a REQUIREMENT for most condenser mics...
The Lexicon Omega does have this but apparently the Aplpha doesn't have it.
That leaves you with the choice of either getting a dynamic mic that doesn't need Phantom, or replacing the Alpha, OR using a preamp ahead of the mic before the Alpha...
Sorry, but those are the only solutions I see for you.
REMEMBER that condenser mics pick up everything and you cannot run them into a PA or they will feedback.
Oct 08, 2010 | Lexicon Alpha Personal Recording Studio
Got a MacBook Pro...problem recording with external microphone
Hi
... sound issues like you are having do pop up occasionally ... the best thing to do is to reboot the system ... sorry.
Cheers.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ronald_f3c54257e2cc2559
Apr 29, 2017 | Apple GarageBand Jam Full Version for Mac...
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
I had a lexicon lambda installed on my old laptop. I lost my installer cd and now can't use my box in my new computer . how do I get the driver ?
Hi here is a link to the drivers for you Lambda.>
http://www.lexiconpro.com/product.php?id=8#downloads
Thank you for using Fixya.com
Feb 10, 2010 | Lexicon Lambda Usb Desktop Recording...
I Installed the Lexicon Lambda and followed all of the instructions to the letter. I can hear sound out with no problem, but when I record, it records from my laptops internal mic. Thus, everything in the...
You will need to go into your sound properties, you can do this by clicking on the speaker Icon thats down by the clock (lower rights hand side of your screen) that should bring up sliders for everything.
Their is also other options and advanced options you may need to enable that could be specific to your devices. but the main thing here would be for you to disable the one mic and enable the one you want and also possibly lower its sensitivity levels.
Apr 17, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
Distortion
It's because when you recording your get sound from Lambda!!! But PC can't reproduce that quality! Try to download driver or update which will allow you to achieve what you want.
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
428 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
