Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
Not heating water
The heater on my dishwasher checks out ok,i get approx. 20 ohms.when in the heat part of the programme i am only getting a live(positive)feed but no neutral(negative).do you have an answer to this problem?
  • DAVID VLIETINCK
    DAVID VLIETINCK May 03, 2007
    with a little more time spent on machine i solved it myself!
  • 641 Answers
Well done !
Posted on Jul 27, 2007
Dishwasher not finishing cycle
A10 4 + 6 Heating circuit Heating element, connections, module,
relay, pressure switch
A10 Open circuit in heating circuit.
• Check the circuit of the heating element (26 ohms).
• Check for an open circuit heater cut-out.
• Check pressure switch open circuit (connections 11-14).
• Check wiring and connections between module card, pressure switch and heater.
• If all above is OK, replace module card.
Sep 18, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Bosch she6ap05 dishwasher not heating
If the unit is not heating, it may give an error message (usually e09) the chances are that it is the heat pump (part number 669135). The circulating motor and heater are combined in this one unit. It is also possible that the power board (situated behind the right side panel, bottom right) is at fault, this needs to be replaced by a qualified engineer as the software is booted by a coding program through a specific computer program. The heat pump will be your first check tho, the heating side is the contacts under the larger connection block and should read approx 20-30 ohms. Hope his helps, if you require more info please add a comment.
Mar 02, 2013 | Bosch Dishwashers
Electrolux dishwasher not heating water
If your Ohms are at "0" then the heater is open.
Jul 31, 2012 | Electrolux Dishwashers
The water in our bosh S9F1B dishwasher does not heat up. The programme seems to work ok, just the pots are cold.
check the water coming into.the unit. must be acertain degrees. the heater will only heat up to a certain degrees .ex if you have cold water going to machine the heater may make it warm.
Feb 23, 2010 | Dishwashers
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
Electrolux de 6850 dishwasher
I followed some of the good instructions already on Fixya. I had checked the heater and it was o.k. I then took the front door of the washer apart to get at the control box. Sure enough, I also had the common design fault. One leg of the rely had scorch marks and was now disconnected from the circuit board. I will solder tonight and test. I include a photo of the burned board. TNoel P8017c86.jpg
May 07, 2009 | Zanussi 24 in. DE6850 Free-standing...
Water heater no go.
The heating element is turned on first during the main wash cycle, which could be approximately 10 minutes in. Since this error is coming up, the first thing to check/replace is the heating element.
I am only familiar with the LDF family of LG dishwashers and on them, to get to the heating element, you pull the dishwasher, invert the entire DW and remove the access panel.
Good Luck, please post back here what you find, OK?
May 07, 2009 | Dishwashers
I have a Bosch SHV55M03GB dishwasher which does not heat the water. The programme cycle also sticks at the last minute. Any ideas, heater element or control panel? Thanks.
If cycle proceed normally after waiting for a while, then the control is probably OK. It stands by a while because it does not read correct temperature before proceeding.
If the appliance is connected to both hot and cold water, open more the hot water faucet.
If the water is not heating at all, check heating element for continuity, using a tester.
If water is heating regularly, but cycle is still slow, check thermic sensor.
Here are more suggestions from Repairclinic:
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
If you need replacement parts or exploded views you find them here.
Oct 10, 2008 | Dishwashers
Zanussi ZSF6160 Water not heating
Mantona, you're on the right track. Your heater terminals are large, insulated and poke through the tub facing downward. To test this, remove one of the wires connected to the terminal, then check OHMS. If this is what you did, you don't have to do that again. Elements rarely fail, the problem most likely resides in the hi-limit thermostat. You know where the element is, now follow one of the wires back toward the control panel. One of the element wires will pass through the thermostat (in series) before going to the control. The thermostat is mounted tightly to the bottom of the tub, touching it to monitor temperature. When you find it, remove one of the wires (there are 2) and check OHMS. You should read ~1 Ohm, if you read infinity, you found the problem. (You can verify your finding by removing both wires from it and connect them together. Then run a wash load to check the heater. Don't leave it in this condition! The thermostat is a safety device and should not be permanently bypassed! If your test of the t'stat proves that it's OK, you'll have to test it with power on and running. I can walk you through this if needed. Let us know how it turns out.
Aug 16, 2007 | Zanussi 24 in. ZSF6160 Free-standing...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
309 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
