Question about Hotpoint WMA35 Front Load Washer
My hotpoint washer drier power on/off button has broken.pls help
Hi my machine is 5 years old, been working fine, when i was pushing the power button to on, it stuck in the off position. Ive tried spraying with wd40, and pushing frimly in and out, to no avail. Really dont want to be paying for another machine for the sake of an on/off switch. Anybody got any ideas?
  • jaynehopkins Dec 29, 2008
    thank you for that, now have confidence to try to find new on/off switch....just gotta hope that it comes with fitting/connection instructions :) thanks again
  • Thomas F. Schneider May 11, 2010
    Could you not go to an appliance parts place , obtain the replacment switch and change it?
    Scholar:
  • 39 Answers
Smithbrother is on to it I think. Those push on push off buttons fail after awhile. You can get a replacement, put it on, or have it replaced. The appliance covers must be removed to detach wires, remove button, put new one in, and reattach wires to the replacement.
Posted on Dec 27, 2008
Hi,how can i reset the language on my wmd960 hotpoint ultima,thanks
1. Switch on the power and when the language is displayed - press the child lock+ temperature+ spin buttons simultaneously for about 5 seconds. Release the child lock button when other languages appear. Scroll down using temperature button-until English is dispalyed. Select using child lock button.
Jan 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF240P on off button stuck in.
If indeed the board is broken, then the price reflects what would be Hopoint's charge, as there repair charge is nearly £100.oo plus the board at approx£80.00.
If it is under 5 years old, then you should be able to claim under the 5 year parts cover.You could fit it your self, as it is a straghtforward repair.
If you need any more info, e-mail me.
Mar 17, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
The door is locked on my washer/drier and the machine is broken,
If you turn off your machine, remove the top then you should be able to reach inside and open the door.
Feb 19, 2010 | Washing Machines
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint first edition few 12p,not working
parts are free but a call out charge is made approx £80.00
Jan 17, 2009 | Hotpoint First Edition FEW12 Front Load...
My washing maching wt741 keeps flashing f-12 could u pls tell me the problem, thank you
Hi.
F12 indicates 2 or 3 differant faults.
Try these first.
Press and hold start/ cancel button for at least 3 seconds, and see if jt works.
Make sure hot and cold water taps are turned on and that you are getting water to the m/c.
Select a drain prog, and see if it pumps out o/k.
If all these do not solve problem, then you have a communication error between boards, this entails calling an engineer out.
If it is under 5 years old then you should be covered by the Hotpoint 5 year part guarantee.
Plz rate my solution .Thanks.
Dec 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drier not working
take top off. you will see drier manifold going across top of machine with stats mounted on it. one or more of these stats is resetteble ie has a little button in the middle. press to reset. some hotpoint have a thermal fuse mounted on the manifold so if present, check this for continuity as well. with top still off, put on dry and check fan working as well.
if you get it going and fault reoccurs, then there is a blockage in the drier duct
Jun 22, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpont washer/drier
if you accidently push the on/off and start buttons together, this put the appliance into a test/demo mode. to cancel it you just need to push the on/off and start buttons at the same time and "d off" should be displayed on the screen and it should now work as normal
May 24, 2008 | Hotpoint Aquarius WD640 Front Load...
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA35 Front Load Washer Logo
101 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
