Make sure the power adaptor you are using is the correct one for the router. the adaptor will be labeled with an output voltage, make sure it matches the label on the router. In the case that the router requires the typical 5-volts, and you have connected a 9-volt, you may have made a brick.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
im trying to forward a port for utorrent on my wireless linksys wrt100 router but utorrent is...
(More)
im trying to forward a port for utorrent on my wireless linksys wrt100 router but utorrent is stating that my firewall/router is blocking it OS windows XP media edition SP2
Got a new gateway. tried to connect router to comcast cable modem. Have tried several times in the...
(More)
Got a new gateway. tried to connect router to comcast cable modem. Have tried several times in the order the instructions stated but there is still no internet access. i called comcast since I thought i needed ISP username and password, they said to use admin and password. and to try the 192.168.0.1 site. I went to the site and i still couldn't understand what to do. I tried several things. And i went to the control panel to install the router and it seemed to act as a dial up instead.
My Belkin Wireless router is on security lock. My daughter locked it by accident. Can I unlock it?...
(More)
My Belkin Wireless router is on security lock. My daughter locked it by accident. Can I unlock it? How can I unlock it?
when I put the connection through the router, I lose the internet connection. I believe it is a...
(More)
when I put the connection through the router, I lose the internet connection. I believe it is a setting in my computer but I am unable to locate it. Do I need to install the drivers or software again?
