Question about Sony SLV-N55 VHS VCR
Sony SLV-640HF Problem
I'm hoping a VCR guru out there might have some ideas on a problem I am having with my little-used Sony SLV-640HF: When the cable signal is run through the VCR (VCR plugged in and off), the picture on the TV is snowy.  When using the tuner on the VCR, the picture is snowy. The VCR's OSD menus are crystal clear.  Pre-recorded tapes play crystal clear.  If I try to record off of cable, it plays snowy.  I have not tried using the video inputs, but it seems to me the problem lies somewhere in the tuner section. Any ideas on where to start to find the problem?  I hate to dump it. Thanks, Joe Woosley I have an slv-n55 with a similar problem. It has a built-in tuner; the cable comes into the house, into the VCR, and then from the VCR output on the VCR into the TV set so I can watch one program and record another at the same time. There is no "box" involved. The TV also has its own tuner. Until a few months ago, everything was working perfectly. No problems with picture or audio even when I was watching a different channel on the TV while the VCR was recording a different channel. Now I've started having audio and video problems with certain channels (mostly local channels, for some reason) with all others ok, even if I'm watching one channel and recording another. Hookups are tight, and no settings have been changed. All things being equal: 1. My cable connection is from Mediacom Cable. Could my problems have anything to do with the signal I'm receiving from the cable company during the run-up to digital conversion? 2. Is it possible for the built-in tuner in my VCR to fail selectively and affect some channels and not others?
    Problem Solver:
  • 13 Answers
I would be inclined to say that there are only two likely problems that you may be encountering. Either you are getting a bad signal feed, or the connectors on the cable are getting old and need replaced. The connection to the cable can break down over time, especially if they have been connected and reconnected several times. I cannot rule out problems caused by the transition to DTV, but that doesnt seem likely if there are only a few channels affected. As far as "selective failure" of the VCR's built-in tuner, I would say that that is also a very unlikely source for the problem If the tuning components inside the tuner had gone out, I would expect to see a problem on all channels watched through the system. If you are having this problem on all channels of the sony, then the tuner could surely be the problem, but if you haven't used it much that would indicate a problem at manufacturing, however since at least one of the machines is working fine on some channels and not on all of them, I would suspect the connections or the signal from your cable company. Contact them first ands see if they are having signal issues, if not try replacing your connectors.
Posted on May 11, 2009
I have a logic tv with built in dvd I have had 3 remotes now and still none of them control the tv correctly
universal remotes are notorious for this issue, all i can suggest is to obtain a cloning type remote and have assess to a proper remote to clone.
Best regards Falco
Oct 14, 2013 | Sony SLV-640HF VHS VCR
The vcr tape loads but does not move three peices fell out when i opened it up a rubber oblong wheel a plastic peice wth a spring any sugestions?
I would search for the service manual, because serious damage as things falling out will often send the VCR mode switch out of position. This device tells the electronics what the mechanial section mode is in IE: fast forward or playback etc. However VCR's mode switches and getting them set up right is nearly impossible unless you have done it many times before - hence the need for the manual. It will also list the part numbers of the broken bits and show where they fit.
If you can't get one free try Manuals In PDF.
Jul 03, 2011 | Sony SLV-640HF VHS VCR
I need a manual for my sony slv-640hf video cassette recorder so I can tape shows in advance Thank you for any help you can give me. :-)
Go to this in your web browser:
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
Enter your VCR model number in the box. Click CONTINUE. The next page has the link to download user guide in PDF format. Click on the link Operating Instructions to download manual.
Jan 28, 2011 | Sony SLV-640HF VHS VCR
I have a sony slv-d100 combo. DVD works fine, vcr NOT!
this is a mecanical problem, is some gears is broken.
Pease send to repair shop, to check
Nov 27, 2009 | Sony SLV-D100 DVD Player/VCR
Sony SLV-640HF VHS VCR ejects any tape after a couple of seconds
While the tape may appear to be loading properly, it is not. These units have a known problem with the grease at the loading arm getting sticky. This means that the tape is not loaded properly and will not move through the VCR properly. This is detected as the hubs not moving and the unit will eject the tape to prevent damage. This is a simple repair for anyone that has done these before, but requires an alignment check. This check requires a special alignment tape and equipment.
This should be a labor only repair.
Dan
Aug 31, 2009 | Sony SLV-640HF VHS VCR
Logik TV Freeview problem.
If you can't access the main tv menu in order to choose a factory reset or initial installation you will need specialist help.
In that case I suggest you contact the Logik website or a local dealer. The instruction manual might help...
Sep 29, 2017 | Sony SLV-640HF VHS VCR
VCR SLV-640HF
The mode switch is the device that monitors the various positions of all mechanical components in the transport area. It is usually an encoder type device, located near the center or right side bottom of the transport. But, before I'd condemn the switch, I would certainly check and see the the transport is "cycling", and that nothing is slipping. This is usually the case when this symptom crops up...accordianman
May 13, 2008 | Sony SLV-640HF VHS VCR
No picture or counter
Are you sure the tape is still moving?...accordianman
Feb 10, 2008 | Sony SLV-640HF VHS VCR
VCR Tape is stuck in Sony Video Recorder, model SLV-620HF.
In vcr you mean? try unpluging the electric cord for 1 hour
then plug it back up. it just might eject it out. mine did.
Nov 11, 2007 | Sony SLV-640HF VHS VCR
Sony SLV-N55 VHS VCR Logo
239 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
