Question about Sony DVP-NS50P DVD Player
Sony DVD Player freezes
2 days ago my Sony DVNS50P stopped functioning properly. I have not had one problem until now.
It will load the disk. It will play for varying lengths of time generally less than 5 min and then freezes. Sometimes it freezes even before it starts to play. The player is 3 years old. Please help.
  • Sony Master
  • 6,487 Answers
This can be a problem with the player lens, you can try first to clean it using a DVD cleaner and then after that try to play again and if still the same problem the lens may need a replacemnet already...
Posted on Dec 26, 2008
  • Sony Master
  • 19,396 Answers
Try cleaning the lens with a DVD lens cleaner disk, this should fix the problem.
    Sergeant:
    Novelist:
  • 327 Answers
Its the problem of the lens and the motor that spins the discks that has to be replaced.and immense cleaning and servicing required. but it will work after that.
My bluray player is a sony have owned it for 2 years but have primarily only played dvd's on it and have had no problems with it working on all types of discs. However recently I purchsed some bluray discs...
Lens cleaner disk works but it is a cd, which does not heat up a bluRay circuit. DVD too does not heat up the circuit. BluRay disks are denser in data(30gB) and runs closer to the lens, so reading disks is more critical. And some movies may heat up the circuit to freeze the functions. Maybe a moisture problem, keep it power on to drive off moisture on the semiconductor ICs.until bluRay disks work.
Oct 28, 2010 | Televison & Video
Dvd not spinning properly
I had the exact same problem.
There was a bad batch of spindle motors (why they didn't use brushless is any body's guess). I replaced mine and it is quite easy. I even soldered in the single-DVD player's (same basic model number, just not multi-disk) motor because I couldn't find the right part for the multi-disk model (or the single was cheaper, I forget). That was years ago and it still works great today (I didn't like the lack of features on a cheap replacement player).
Apr 08, 2008 | Sony DVP-NC675P Multi-disc DVD Player
Sony dvd player DVPCX995VMakes grinding noise and door won't open
I was able to fix this myself, however, I did get instructions from Sony that may or may not work. My solution was:
Unplug the unit and carefully (so the disks don't shift) move to a location where it can be easily worked on.
Remove the 9 screws holding the cover on. 2 on top, 2 on each side, and 3 at the back, along the top edge.
Carefully, may need some wiggly remove the cover. There are some rubber pads at the front of the unit that hinder the cover from sliding. Slightly wiggling and pulling to the rear will dislodge it.
Confirm all disks are properly aligned on the carousel.
Pull out any disks that are askew. They will be replaced later in the same way disks are added, through the door.
Look in the rear where the laser unit is.
Carefully slide out disks near the laser. You'll have to move some in order to tip others out.
By taking out 6-10 disks, you'll probably find there's one partially lodged in the laser unit. With adjacent disks removed you can slide the "stuck" disk out.
Plug in the unit and test to see if the grinding stopped.
Unplug the cord.
Replace the cover with the 9 screws. Some wiggly and pushing forward is needed to reseat the cover at the front.
Carefully move the unit back to where it was.
Replace cables and plug in.
Return the disks removed according to the instructions.
This took me about 15 minutes from start to finish.
The following was provided by Sony. I don't know if this works as I had fixed it before Sony responded.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons. NOTE: This step may not apply to all models. DISC1 is not available on all DVD players.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Oct 11, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony dvd player dvp-fx810 stuck on "disk loading"
Make sure the switch on the side is set to video out not video in hopefully this helps out
May 16, 2009 | Sony DVP-FX810 Portable DVD Player
Blu-ray disc not playing movies
Try resetting the machine. Take the movie out, close the tray, press and hold both the stop and power buttons simultaneously until the machine shuts down completely... then turn it on. It will ask you for the first time settings again... beware that mine stated like that and the freezing movies until "No Disk" came up and now nothing will be read. I an taking it to Sears for an exchange (hopefully). I am disappointed with the performance so far. It's a SONY ****!
Jan 29, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Dvd loading
mine kinda has the same problem but it only happens with one movie Hairspray but it doesn't say error it just says loading for hours until i restart this system in order to get the DVD out. Need Help!!
Feb 16, 2008 | Sylvania SRD3900 DVD Player/VCR
Matsui Portable DVD player
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Jan 24, 2008 | Symphonic WF803 DVD Player/VCR
Sony RDR-VX500 does not load some dvds, disc error.
Try the disks in another DVD player. If they play with no problems in another player, then you have a hardware issue with your Sony. Nowadays, if it is out of warranty, fixing it is not worth it, because it is cheaper to replace, at least in the USA.
Nov 27, 2006 | Sony RDR-VX500 DVD Recorder/VCR
Sony DVP-NS50P DVD Player Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
