Question about HP Pavilion xf328 PC Notebook
Start up problems
My hp pavilion xf328 quit working on me one day and now when i start it up it just makes four loud beeps, beep....beep....beep....beep and then its skips a couple seconds and does that again. someone told me it could be the ram need to be reaseated but i opened the ram cover and there is no ram to take out.
  • Chris Hingee
    Chris Hingee May 11, 2010
    You should check all the panels, there will be RAM (memory) located somewhere. The empty slot you saw could be for some other device that was not installed.
  • Christopher Sherwood
    Christopher Sherwood May 11, 2010
    when the computer turns on and you then hear the beeps, are they all the same length, sometimes, beeps codes for example do a couple of short beeps and one long one and other combinations.
How to disable touch pad on hp pavilion ?
you can go to control panel under mouse/touchpad and you can disbale it there , or go to device manager and look for the driver for the touch pad and disable it .
Thank you.
Dennis
Sep 08, 2014 | HP Pavilon xf328 (F5913HRABA) PC Notebook
Lots of beeps on startup of HP Pavilion DV6000 entertainment pc
Beep Codes
Beep signal Additional indicators Meaning
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Jul 07, 2012 | Computers & Internet
When i start my computer it makes a loud beeping noise it is a acer aspire4520
What you are hearing is probably a BIOS beep code.
Beep codes are a bit like Morse code, and are used to indicate certain faults with the hardware.
The codes change from manufacturer to manufacturer, but generally speaking one beep = System OK, so if your PC is starting up normally and you have no other problems there is nothing to worry about!
Hope this helps,
Matt
Jun 08, 2010 | HP Pavilion dv6000z Notebook
Dv6000 touchpad volume annoying beep
you can not disable it, it is saying this is how loud it is
Mar 15, 2010 | HP Pavilion dv6000z Notebook
My hp pavilion ze5185 keeps making really loud beeping noises when i start it up
Only on start up? and does it load windows? if not then one of your start up file have bein deleted by a trogan worm or virus ......sry i wish i could help more but i need more info
Oct 25, 2009 | HP Pavilion ze5185 Notebook
Boot up beep and blanck screen
The beep patterns always tell you what the problem is, but it depends on what kind of BIOS is in your computer. You can take a look here, maybe you find what is the problem with your machine: http://www.pchell.com/hardware/beepcodes.shtml
Apr 11, 2009 | HP Pavilion dv2500t Notebook
Computer: laptop HP dv5000 OS: Win XP Age: purchased 2006 My compuer makes several loud beeps. Then It locks up. I have to crash it by holding down the power button. This started yesterday. ...
What the beeps are for is to alert you that there is a component that is not going smoothly through POST(Power On Self Test) This is a test that the motherboard runs everytime you start your pc. It is the boards way of double checking hardware and that the most basic software to find the windows installation is in order.
These beeps could generally be the same but different according to the manufacturer of the computer.
This is what I need you to do so I can effectively provide assistance. When You turn on your Pc i need you to count how many beeps it is making, as well as frequency. Like if they are short beeps or long beeps. Thats the difference you need to listen for. It may sound randoom but there is a pattern that the motherboard is trying to convey to you to state what is wrong with it. Record the beep sequence and provide me with a little more information on your pc and we will see where we go from there.
Mar 25, 2009 | HP Pavilion dv4000 Notebook
Installed memory cpu is making a loun beep and wont boot up
Ram is not supported or installed incorrectly, try readjusting it, then reset the CMOS and try again. If ti doesn't work after the readjust make sure that the ram speed etc is supported by your motherboard.
Dec 22, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computer will not boot. was making some loud noise before it stopped working
I just had the same problem to deal with. My computer automatically turned on, and just when you thought it was gonna work, there was a single, loud beep. I immediately unplugged the computer. Make sure all the cords and chips are properly and securely connected. My problem was that my memory cards were loose. Maybe that'll help.
Jun 17, 2008 | HP Pavilion A1050y (PU131AV) PC Desktop
Computers & Internet Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
