Question about Homelite 'Yard Broom' Leaf Blower
Can not get a gas blower going - Homelite 'Yard Broom' Leaf Blower
  • lawnmowerguy May 11, 2010
    give more details
  • 398 Answers
Spray starting fluid in air intake
Posted on Mar 02, 2009
Backpack gas blower
Monching, You will have to hope there is not too much damage done already from running straight Gas. Empty all straight gas from blowers tank and refill with proper minimum 50:1 gas oil mix. Start blower and run on 1/2 throttle for a few minutes to be sure its going to be OK. If seized, you will have to try and unseize and if lucky it may run if not too much damage internally. You should run a heavier oil to gas mix 32 or 40:1 in an engine that's been seized. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
this is what happens when someone run straight gas in two cycle engine
Fixing seized up echo weed eater
Stihl FS120 Grass Trimmer RAN WITH NO OIL IN GAS Blown Top End
https://www.askmehelpdesk.com/tools-power-equipment/ran-leaf-blower-without-oil-36071.html
Jul 12, 2016 | Craftsman 25cc 2-Cycle Gas Blower/Vac
My blower seems to not want to go to ful throttle
This happened on my older Ryobi as well. Turns out it was the fuel lines. The ethnol in the gas made the lines swell up inside.
Oct 20, 2014 | Ryobi Blower Vac 205mph Leaf Blower Or...
What's mis ratio for ECHO PB-400E blower
Two very good answers, if you go to use the 50:1 ratio you will probably not be wrong most new stuff mixes with the 50:1 ratio these days if your not comfortable mixing the gas, Menards has premixed can for sale, as do most of the big box stores. Very good for novice mixers who don't want to keep alot of fuel around and let it go bad. Great alternative to mixing!
Jun 21, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
While running blower starts dying down in power going up and bown and cuts off
I wonder if it is starting to seize. Have you been using cheap ethanol gas. Or have you done research online for gas stations that sell real gas? If you don't use real gas on a 2 stroke engine it will over heat and eventually burn the valve and cause distortion all over. It will eventually seize.
http://pure-gas.org/
Oct 21, 2013 | kawasaki Krb750b Backpack Leaf Blower
Gas/oil mixture for muculloch 400048-04
If you mix it 40 to 1 you won't go wrong. Better to see a little blue smoke than blow a motor. However, most of these use to have a 50 to 1 mixture. That's 50 parts gas and 1 part oil. Otherwords, 500ml to 5 gallons of gas.
Nov 17, 2010 | McCulloch 26cc Gas Blower Mcb3208
Where can I purchase a silent gas leaf blower
Go to www.solousa.com, there you can find a dealer in your area.
Good day.
Oct 20, 2009 | Solo 471 Silent Gas Blower 52 Cc
Fuel mixture for 32 CC McCulloch leaf blower
Gas to Oil ratio is 40 to 1. (40:1)
Oct 12, 2008 | Garden
Wont stay lit after 20 min with blower on
As a licensed plumber I will recommend now that you don't touch the heater. Gas is dangerous and leaks aren't easily found.
Everytime a gas heater is serviced the tradesman needs to do a gas check to see if all is working well. There are too many things that can go wrong, from a small gas leak to burnt gas leaking, all of which are lethal.
I can tell you how to fix it, but I won't, because it is too dangerous.
Getting a repair man will cost you, but not getting one may cost you your health or your life.
Dec 30, 2007 | Heating & Cooling
Homelite 'Yard Broom' Leaf Blower Logo
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
