Question about HP Pavilion dv1000 Notebook
HP pavilion dv1000 is not compatable with ATT woreless in the home. The computer if in range will shut down and reboot continually. Works with other wireless systems.
  • theadamray May 11, 2010
    Have you tried updating the drivers for the wireless card?
  • Curtis Richner May 11, 2010
    Have you tried another system on the ATT wireless?
  • 520 Answers
Uninstall the software look for updated compatable drivers,or once pc has started go to control panel select administrative tools , services , and scroll down to wzc(windows zero config)
select it and start it.close all box's and now you can use wifi using window based drivers(cos its the devices program(manager)that is incompatable not the actual device and the device is installed but its program disabled.
Posted on Jan 24, 2009
HP Pavilion Laptop -- massive power problems?
hello chad
Seem to be circuit issue.
You can check charger with volt meter to check its working ok.
Drain all resistors of power by removing battery and charger and holding down power button for 10 seconds.
There is a power button board that can be bad.
I like to break things down by just powering the laptop with memory and keyboard, power button board only. this will require removing motherboard power button board so it will only be the parts to POST.
Minimal Post .
It can be an array of things from the systems casing shorting it out to other hardware.
Jan 04, 2014 | HP Pavilion dv1000 Notebook
Hp dv1000 does not power up
maby the charger is not compatible with your laptop.
Aug 25, 2012 | HP Pavilion dv1000 Notebook
My hp pavillion dv 1000 shut down then turns back on but the screen is black and it reboots itself every 5 sec.
thats a trojan or virus in your laptop,i suggest u format or boot from cd/dvd rom with a compatible operating system disk(WIN7/XP/VISTA/2000),THEN U DO system repair..THAT IS IF U HAVE ANY IDEA ABOUT IT,IF NOT,TAKE IT TO UR REPIARMAN
Nov 25, 2010 | HP Pavilion dv1000 Notebook
I have a hp pavilion dv1000, it keeps shutting down, I had the fan replaced by Hp six months after I bought it. Is there a recall for this lemon?
are you sure that it shutting down because of fan
it may be a virus problem or OS problem too
try to find out main problem
thanks
Nov 12, 2010 | HP Pavilion dv1000 Notebook
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
Is there a compatible USB-PCMCIA card for the DV1000 by HP? None of the ports work on my son's hand-me-down computer and he needs at least one for printing. The geek squad wants $150 and for that, I'll...
Here ya go, $13
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124011&cm_re=pcmcia_USB-_-15-124-011-_-Product
ALso, try this
Go to device manager, usb root hub, right click, properties, power management tab, uncheck the box allowing windows to turn the device off to save power, repeat on all usb root hubs, reboot, see if USB ports work.
Nov 29, 2009 | HP Pavilion dv1000 Notebook
Keep shuting down.
reinstall the oerating system...................this will help.......................Sameeraryan
Jan 13, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 works fine on CRT but no LCD screen
Sounds like the LCD backlight or inverter went bad. More probably the inverter,and that's good because,of the two, it's usually cheaper and easier to replace.
Before considering those,check the lid switch to make sure that it is operating correctly and not stuck down.
Ron
Dec 10, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000
i have the same problem here.. i re-install windows, home premium to Xp pro sp2, and my note book model is Hp dv1000, i downloaded driver from hp site but it does't help... i can't even connect to internet.. i think i need the whole driver.. sounds did't work, and even the quick play bottom... can any one help me. thank you
Dec 26, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
155 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
