Question about Hoover S2105 Slider Bagless Stick Vacuum
I need to know how to put together a Hoover Slider vaccum. I had to take it apart and now i need to put it back together.
3 Suggested Answers
Kazong
  • 152 Answers
SOURCE: Hoover upright vacuum information
cant help with manual but if i may why would u take it apart theres not much to service but to take the belt off turn the machine over and down by the roller there are a few screws take them out the cover should come off and thats it
Posted on Feb 06, 2008
SOURCE: HOOVER STEAM CLEANER PROBLEM
The switch in my hover steam cleaner is broken, how do I repair it
Posted on Feb 15, 2008
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
Can i fix a chewed apart cor on a vaccum cleaner or do i need to replace cord
fix it!! with it unplugged, strip both ends of the chewed area to bare wire and then splice them back together. Wrap the splice with electrical tape!
Dec 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
Brushes don't work on my hoover steam vac v2
The bearing on the inside of the turbine is rusted. You will have to take the hood of the unit and unscrew the black piece that has to rub hoses going to it. Then take apart the black turbine. Inside you will find 2 white gears and a small 1/2inch bearing. Use wd40 to uncease the bearing. After this put the take pliers and make sure the metal post will turn. Spray wd40 on everything you see including Hoover for making such ****. After this put put everything back together. Now the best thing to do is get some automotive bearing grease and put a large amount on bearing and and other metal parts. Put everthing back together. Clean any hair off the brushes and you are ready. Now the bad news if your gears are worn you will have to replace the turbine. Go to an internet website and the part number will be 91001019. I know all this because I spent 6 years working for Hoover and they found it cheaper to send our jobs overseas.
Apr 11, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Hoover Slider, Model #S2105, Serial #050500084989, and I need instructions on putting it back together; with parts and assembly of parts. I took it apart because it was making a noise, and I...
Greetings from GoVacuum,
Please see the link below for a parts schematic to your Hoover Slider, hopefully this will help you put the machine back together. If you find a part that is missing, and would like to order one, just shoot me an email at chris.jones at govacuum.com, and I can give you a price on it.
Please feel free to send me an email should you have any further questions.
Chris Jones
GoVacuum.com
Sep 29, 2008 | Vacuums
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Savvy Bagless; wind nozzle doesn't turn
has it been taken apart before? if so it wasn't put back together right.call me and i will walk you through putting it back together so it will work.i don't charge for the help just like to help people
Aug 15, 2008 | Hoover U8145-900 Savvy Bagless Upright...
My hoover windtunnel u6323-930 has dust leaking into air when unit is on. i think it is in the housing I cannot see and I need ti know how to take apart to determine which part i need to order thanks ...
You will just have to start taking the base aprt until you can get the motor, Just remember how it was so you can put it back together correctly again. When you have the motor off, look at the fan chamber, you probably have a crack or hole in it. You can replace the part if it is bad #38736019.
May 31, 2008 | Hoover Vacuums
Repplacing power cord on Hoover Wind tunnel (not self propelled)
I am thinking that the cord goes in on the back, just below the handle. Remove the handle, then from the front, remove the tool holder(#8), then you can get to where the cord comes in and hooks up.
Feb 12, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover S2105 Slider Bagless Stick Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
