Question about Dryers
I have a kenmore series 80 dryer model 110-70812990 that i heard a bang then the drum stopped turning and i smelled burning rubber. I'm guessing that the drive belt broke. How easy would that be to repair ourselves and how would we do it?
Removing the back wont help because you can't access the motor, pulleys or rollers from there. You have to remove the front panel which is easier. Make sure you unplug the dryer first, then you can open and tilt back the top, it's just held at the 2 front corners by clips which pop off easily enough. Once you have the top open, unplug the door switch wire connector. There are 2 screws that hold the front panel to the side panels, one on each front corner. When you remove them, the front panel can be pulled off. Before you do that, tilt the dryer on it's back, Use an old blanket or something to pad the back. If you don't tilt the dryer back, when you remove the front panel the drum will drop forward. Once you have the front panel off you can see if it was the belt that broke or a pulley or roller. You can also pull the drum out by lifting straight up.
Good Luck.
Posted on Jan 01, 2009
  • bodaddy Jan 01, 2009
    Our series 80 is 11 years old and I have repaired it several times.
    President:
  • 2,692 Answers
Remove back of drier after disconnecting the power cord. Find old belt laying on floor under machine. Obtain new belt and place around drum and motor pulley. done
Posted on Dec 26, 2008
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Kenmore 11062612101
From your description, the dryer belt could be in need of replacement. The burning smell could come from the motor pulley spinning and trying get a grip to turn the drum.
Dec 20, 2013 | Kenmore series 70 80 90 Dryer Motor...
My kenmore series 80 makes a lot of noise and has a burning smell
They could be. Is the smell electrical or rubber.
Feb 03, 2013 | Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
I have a Kenmore Electric Series 80 Dryer that the drum inside won't turn but it heats up and smells hot like something is burning. I can however turn it manually.
Remove the top and the front panel to remove the drum after you purchase a belt and teh idler pulley that Sears selles for your dryer. The pulley's bearing has froze up causing the belt to burn up and falling off
Jan 22, 2011 | Kenmore Dryers
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
My dryer drum stopped turning. The dryer will turn on
it does sound like the belt is broken. you will need to access the inside of the dryer by removing the front. they all come apart differently. Make and Model would help me tell you more.
Dec 26, 2008 | Dryers
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 80 series stop turning
most likely a bad motor; expensive.
May 19, 2008 | Kenmore 63942 Dryer
Dryers Logo
177 people viewed this question
Top Dryers Experts
Marvin
Marvin
