Question about Acer Aspire 4315 Notebook
Laptop won't boot
My acer 4315 laptop will not start. when the button is depressed, it stays lit for several seconds, blinks once, and stays lit for several more seconds before going off. the display remains black throughout.
I've tried removing power (both battery and adapter), but cannot get it to boot up. please help
  • conniemoss10 Dec 27, 2008
    Dearest
    dearest geekman,
    thank you so much. I'd forgotten that I'd have to reseat the memory in my grandkids' old desktops when they "died". You have brought me back into this century.
  • Acer Master
  • 32,281 Answers
Hi Connie,
This problem usually occurs if you have faulty RAM (memory)module or it may only need to be reseated to make proper electrical connection.
On the bottom of the laptop there are one or two panels, under one of these panels will be the memory module/s, you need to remove the screw/s securing the panel to reveal the memory. The memory modules are secured with spring loaded catches on the sides of the module, apply pressure to the side of the caches to release the memory module, remove and insert it a few times so it will make proper electrical connection.
Reboot youe laptop and if the laptop still does not work then the memory module most likely is faulty and needs to be replaced.
Posted on Dec 27, 2008
My Acer Laptop will not boot up; after pressing the start up button, it blinks slowly.
slow blinking normally means the pc is in hibernation. Make sure the mains plug is in and the pc is not working off the battery and hold down the ON button for several seconds.
If this does not work, remove the mains plug AND the battery, wait until the blinking stops and then replace them and try again.
Mar 28, 2010 | Acer Computers & Internet
My acer aspire 4315 laptop screen goes dark
ASPIRE ONE BIOS FLASH RECOVERY
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
http://support.acer.com/drivers_download.aspx
http://blog.shimpossible.com/2007/07/18/white-screen-of-deat­h/
Mar 05, 2010 | Acer Aspire 4315 Notebook
Black screen acer aspire 4315, changed screen & inverter but still no joy any help please.
If the screen is black and the power light & fan still work....try this:
Jan 19, 2010 | Acer Aspire 4315 Notebook
Replace hard drive acer netbook 8 gig
Back up all info
Insert CD / DVD Win OS into Cd / DVD drive
Shut down laptop / remove battery / depress strat button several times to de-energise system.
Remove tiny screws under the laptop to access HDD, Be very careful prizing off cover so as not to break it.
Remove HDD carefully, you may need to unscrew HDD
Replace with new HDD / replace cover
Start Laptop and depress F1 or F2 to get into bios, alter boot sequence to CD as first boot.
Follow on screen instructions to format HDD / load Windows.
You must have a legit copy of the Windows disc and CD key
Dec 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 4315 Blank Screen!!!!!!!!
You need to Revive the bios back.
Search for Acer bios revive in google
Dec 19, 2009 | Acer Aspire 4315-2963 Notebook
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
Nov 15, 2009 | Acer Aspire 4315 Notebook
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Jan 25, 2009 | Toshiba Satellite A105 Notebook
Acer Aspire 4315 Notebook Logo
115 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
