Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Tv turns on and than red status light comes on and shuts down
I turn my wd62525 Mitubishi and I get sound and I hear the fans running, I hear sound but no picture. Than after 1-2 min. the Status light comes on steady red and tv shuts down and turns the fans off. I hit the rest and after the green lite stops blinking I can turn it back on and it does the same thing. I replaced the lamp and still does the same thing.........can u help?
  • 2 more comments
  • Paul Langkau
    Paul Langkau Jan 03, 2009
    ima_rm2000, I just wanted to tell ya thanks for the solution. The 2 caps where bad and I just had new ones soldered in and the tv works awsome. Thanks again Paul
  • shawnee12 Feb 13, 2009
    i have mitsubishi model wd62825 turned by itself and will not turn back on. it has a flashing red status light and no picture or sound what can i do?
  • Anonymous Feb 14, 2009
    mine is diong the same thang
  • Anonymous Mar 20, 2014
    Hi! We have replaced the lamp twice in our tv. The tv works for a while and then the picture starts getting distorted and the colors are pink and purple. You can hear a noise. When we shut the tv off and let it cool down, it works fine for a while. Is there a fan that may need fixed?
  • 179 Answers
It sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
Posted on Dec 29, 2008
My Sony KF-42WE610 on power up fan comes on and just a short buzz every minute or so on power down red light comes on stand by but won't shut down i hear the fan running so i had to unplug it.
I think that this is a ballast issue you are not suppose to hear any weird sounds coming from your TV set and if this ballast board is not working it will not be able to turn on the lamp this boards are not that expensive they range from $65.00dls to $90.00dls you need to take the ballast out and get the part number of the board to find the right one
Sep 14, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Have wd62525 mitsu status light flashes tv wont
The status light flashing usually indicates the lamp cover door or the side air vent door are open or the switchs are not working.
Mar 16, 2010 | Televison & Video
Getting a loud buzzing noise in the rear of my Mitsubishi wd-52327. The sound is coming from the fan area. Originally i thought the fan was bad but after review the fan seems to be working fine. When...
is there a large amount of heat coming from the back? I had a similar issue w/ my tv, and it ended up being the lamp - but a trick that i was able to use to extend the life a little longer was to power the tv off, grab a can of compressed air (can get it anywhere, usually just a buck or two) and blast it right into the vents in the back, cleaning out the dust that accumulates from normal usage. If it is, in fact, the lamp, it's not a tough fix - email me if you have any other questions! Good luck!
Sep 12, 2009 | Mitsubishi WD-52327 52" Rear Projection...
My wd52327 turns on and than turns itself off
Thats a very common problem which means that the capacitors on the power PWB have most likely failed. You can get the repair kit which has the replacement Capacitors and step by step instructions with detailed pictures on how to do the repair . Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jan 24, 2009 | Mitsubishi WD-62525 62" Rear Projection...
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Red light stays on
First before a reset the set must turn on, if the set just sits there with the red LED on you have further problems, so does the set display anything?
Oct 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
228 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
