Question about Coolmax CD-350-COMBO (CD350COMBO) Infrared Adapter
Bought a coolmax cd 350 combo cable for my none working hard driv
The problem is that my laptop does not detect my old hard drive thru the multi funtion coolmax 350. what can i do?
2 Suggested Answers
SOURCE: I bought an All-in-One Multifunctional
I have spent hours trying to figure out how this damn thing works since the instructions require the user to have way more computing skill than I. First, the thing comes apart, one part being the interface and additional power supply and the other being the power supply that may connect to the Coolmax or your HD power supply if not operational through the Coolmax. If your old HD is larger than 3.5", you may have to connect the power plug to the HD 4 pin power source. otherwise, connect old HD to the Coolmax CD 350 adapter and then connect the Support USB2.0 to a USB interface on your new computer. If your old HD is a 2.5 SATA , do not connect the red power plug to a USB2 interface on your new computer unless you are positive the old HD operates over 5V. Connecting the red USB power source to your new computers USB2 interface may cause the old HD to shoot sparks and smoke, and you will not need the device any more.
Posted on Jan 14, 2009
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Cool max cd-350-combo does not reconize ide drives when connected to pc. System acknowledges that a mass storage device is present but does not show in my computer or disk management (so ya cannot change...
Don't know if you've solved this problem, but I was having the same issue using Windows 7, 64bit. It had been working but Explorer crashed & Explorer restarted, it recognized the device, but I couldn't access the files. I tried it on another laptop & it worked. So I left it plugged in & restarted the computer and that fixed the problem. If that doesn't work, you may have to uninstall the driver that windows automatically installed for it & then plug it back in & have windows reinstall the driver. Good luck.
Sep 12, 2010 | Coolmax CD-350-COMBO (CD350COMBO) Infrared...
Won't acknowledge drive
Sounds like your leads test your IDE or SATA leads
Jul 25, 2010 | Coolmax CD-350-COMBO (CD350COMBO) Infrared...
Does the Coolmax-350-Combo work with Microsoft Vista? The box it came in says it is compatible with Vista, but the online guide doesn't. I am having problems with this product. I need to copy a hard drive...
My approach is to put the old hard drive into the spare slot of the new computer. There should be an IDE cable plug somewhere. Makes things easy. I also use Clonezilla to transfer data.
Apr 08, 2017 | Coolmax CD-350-COMBO (CD350COMBO) Infrared...
I have a Coolmax CD-350-Combo converter. I plugged everything in and it has power, but I can't find the program on my computer. It makes a noise when I plug the USB in but I am not prompted with the...
Hello
Ok, if the computer makes a sound, without notifying you that the device is not recognized, here is something you can try.
Go to:
Start
Control Panel
Administrative tools
Computer Management
Storage
Disc Management
Now you should see your drive in the schematic below, right click on it and choose to assign new drive letter and paths.If there is no drive letter assigned to the drive, assign on, otherwise just choose the option to change the drive letter.
Hope this can help you.
Kind regards
Andrea
Nov 16, 2009 | Audio Players & Recorders
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
I bought a coolmax hd-250B-u2 sata enclosure case and my computer doesn't recognize the hard drive that i have installed...help!
What drive did you put in there ?
Make sure it is connected directly to a USB 2.0 port on the computer some enclosures dont like hubs and even if it did work from a hub you should ensure the hub has its own power supply. Also only use the cable that came with it not one that looks the same that you may have lying around.
If this information was useful please click
Aug 14, 2009 | Coolmax HD-211-eSATA Hard Drive
I have a dead hard drive 2.5" SATA
If it is truly dead and you MUST have the information from it then the only real alternative is to send it to a data recovery expert. These services are NOT cheap
If it clicks or makes random noises clicks pings etc then it is most likely dead I am afraid.
Jul 19, 2009 | Coolmax CD-350-COMBO (CD350COMBO) Infrared...
I bought an All-in-One Multifunctional Converter (Coolmax CD-350-combo) to transfer my data from my non-working laptop to my new laptop. The problem is that it doesn't fit into my hard drive. My old laptop...
Nov 29, 2008 | Coolmax CD-350-COMBO (CD350COMBO) Infrared...
Nero burning on cd writer
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Oct 08, 2008 | Compaq Presario 1200,1600 (297657-001)...
Coolmax CD-350-COMBO (CD350COMBO) Infrared Adapter Logo
93 people viewed this question
Top Coolmax Televison & Video Experts
Are you a Coolmax Televison and Video Expert? Answer questions, earn points and help others
