Question about Keystone Adobe Photoshop CS2 Instructor-based Video Training for PC (793573439024)
"Flatten image" is not possible from Layer menu (greyed out)
I am trying to flatten the image and to have a 2 color palette starting from RGB mode. If I try it by going to Image>Mode>Indexed, I am not able to select Palette>Exact, since Exact is greyed out. How can I get the "Exact" palette to be available?
Thank you.
Joan
How do I place a watermark on a photo with photoshop?
0. Paste or create a layer over the top of the 'main image'.
1. Select the layer you want to be the watermark.
2. Change opacity to what you want, ensuring you can still see the layer underneath it.
Note: you could also change the blending on the watermark layer if you wanted a different effect.
Dec 31, 2014 | Adobe Photoshop CS2 for Mac
I am trying to create a poster for a fundraiser. I can get as far as creating the legal size of it, but then I do not know how to put the 4 pictures onto it and then move them around and resize them. I...
Create a new file, then for each image you wan to add, go to the File menu and choose "Open as Layer". Then you will be able to move each layer around independently. For your text, go to the Layer menu, and then choose "New Layer". Then use the text tool and put your text in that new layer. To move layers, click on the icon in the tool panel that looks like a plus sign with arrows at each tip. You will click on that tool, then click on the layer you want to move in the layer palette, then click on the image and drag to move it.
Mar 16, 2011 | GIMP GNU Image Manipulation Program
I cannot edit my pictures.
When you first open a picture file (particularly an image file you got from the web) it might be locked. Check on the Layers palette to see if you see a padlock symbol like this:
If the file is locked it is because it is in "Index color mode" and you need to change it to RGB.
On the menu bar, go to Image > Mode > RGB.
Your image will still be locked, however, now you can use the Layers palette again to make a duplicate of your image. Click, drag and drop your "Background" layer to the Create New Layer button, like this:
Now you will have two layers: Background (Locked) and Background Copy (not locked). You can drag and drop the locked layer to the trash can if you want to (you don't need it anymore).
You should now be able to edit the new Background Copy layer freely.
Oct 04, 2009 | Adobe Photoshop 7.0 for PC
Tool palette freezes
There are a couple of possibilities. 1. Confirm the image is in RGB color mode, sometimes CMYK or Index color will lock tools (Image->Mode->RGB) 2. Sometimes part of the image is selected, even though you may not see it. Try using ctrl+d to make sure you have de-selected all of the canvas. Good Luck!
Aug 08, 2009 | Adobe Photoshop 7.0 for PC
Psd to jpg
You probably need to flatten the image to get it into a background layer only. Choose in menu: Layer/Flatten image then try to save your image.
If it didn't work, then most likely your image is in 16 bits/channel mode, change it to 8 bits/channel. Choose in menu: Image/Mode/8 bits/channel.
Dec 19, 2008 | Adobe Computers & Internet
Green layer on scanned image from ADF Simplex
What model of scanner are you using? Is it white light based or RGB LEDs (Light Emitting Diodes). Very rarely it may happen that the Red and Blue LEDs are not glowing may be because of loose contact, but this very rare occurence. Try reloading driver software.
S. Mohan
Aug 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Undo White Balance Sony F707
If you have Photoshop: Layer>New adjustment Layer>Levels Use the middle eyedropper tool and click on something in your photo that should be gray/dark gray. Or: Use the white eyedropper (far right eye dropper) and click on something in the photo that you know is (or should be) white. You can try the gray first, then the white.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Keystone Adobe Photoshop CS2 Instructor-based Video Training for PC (793573439024) Logo
351 people viewed this question
Top Keystone Computers & Internet Experts
Tom Chichester
Alexey Krenvalk
Alexey Krenvalk
Toby Clement
Toby Clement
Are you a Keystone Computer and Internet Expert? Answer questions, earn points and help others
