Question about Toshiba TDP-MT500 Multimedia Projector
Magenta tint to the projected image
Hi, Our Toshiba projector has suddenly developed a magenta tint to all images. However, the startup image looks okay. Could it be the bulb? (its high in the auditorium and is not easy to replace or I would have tried it already)
    Problem Solver:
  • 14 Answers
The Lens assembly requires service. The dust is inside the panels.remove the dust and that will work fine
Posted on Jun 04, 2007
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
Toshiba TDP-P5, used unit. Startup image comes up ok. When PC is hooked up, the image does does not change from startup. Cables test okay on other projectors, the video port on the PC is working ok on with...
Try pushing the source/select button to make the projector look for a source. It is the button that looks like a bent arrow right in the middle of the 4 arrow buttons.
Jan 14, 2011 | Toshiba TDP P5 Multimedia Projector
InFocus LP540 Red Tint
first swap out the source cable. if the problem persists, reset the settings to factory default. if the problem still persists, your colorwheel may be bad.
Oct 29, 2009 | InFocus LP 540 Multimedia Projector
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Can't get the projector to project an image from my laptop.
Yes you need to press something on your laptop ...maybe FN +F3 or FN+F4..but after you have image but your projector still turn of...then follow my next comment.
Takecare..
Apr 19, 2008 | Computers & Internet
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Poor image being displayed
Hi guys
You will be looking at either repairing or replacing the Mainboard where all the colour processing is done.
Sep 27, 2007 | Dell 2300MP Multimedia Projector
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Tinted image
If you are plugging in a monitor cable, it is most likely a cable issue. I would try another cable and make sure the cable is seated firmly into the projector. If that doesn't help, check the port on the projector for bent or missing pins because it seems that not all of the video information is reaching the unit.
Feb 02, 2007 | Sanyo PLC-XT16 Multimedia Projector
Toshiba TDP-MT500 Multimedia Projector Logo
257 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
