Question about Uniden TRU8885 Digital Answering Machine
How do I get 2 Uniden TRU8885 base to operate as one base?
I have a Uniden TRU8885 phone system. It works great. I want to add a second Uniden TRU8885 base to my system. I want both bases and all headsets to communicate with each other as if there were only one base. At the moment, each base uniquely registers each headset to that particular base. Is there a way to get the two bases to operate as if they were one base?
Thanks and Happy Holidays,
CB
  • 35 Answers
NO ONLY DECT 6.0 MODELS ARE ABLE TO DO THAT, NOT YOUR MODEL.
Posted on Sep 07, 2009
I have a Uniden TRU8885 - 3 Base, when I plug into power suply, it turn on, but after the base turn on and display the message welcome, the base turn off
buy higher capacity power adapter 9volts 1000mA capacity and use ensuring correct polarity, it will work. i had the problem and adopted this and this works ok. also ensure your handset battery is new and charged after installing the higher capacity power adapter. good luck. venkataramani
Aug 27, 2011 | Uniden TRU8885-2 Cordless Phone
Need operating instructions
Here you go: http://www.uniden.com/pdf/TRU8885-2om.pdf
If I have fully answered your question, please click on fixya and feel free to ask any follow-up questions you may have.
Jul 17, 2009 | Uniden TRU8885 Cordless Phone
Second phone doesn't work.
there is no code to connect.. the problem must be with the signal, the second phone is not receive the signal.. so it is not working, Plz do rate me;...
Jun 26, 2009 | Uniden TRU8885 Digital Answering Machine
Handset No2 displays out of range message
Please check that you have correctly registered the second handset to the base. It may be necessary to de-register the second handset and then re-register it. "Out of range" just means the second handset is not within range of the base phone it was registered to.
Mar 08, 2009 | Uniden TRU8885-2 Cordless Phone
Uniden PowerMax 5.8 no audio transmission on two of three remotes
If phone is more than 1 yr. old, battery needs to be replaced, if not reset base by disconnecting power, pressing and holding delete key while reconnecting power.
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Uniden TRU8885-2 Restarts every time an incoming phone call, start showing the Welcome message ....
YOUR batteries are bad and not giving full current to phone.Clean charging contact and see battery gets full charge. IFthe battery indicator will show full charge due to voltage but once if you remove battery and put it again indicator will be minimum. then replace batttery.
Oct 07, 2008 | Uniden TRU8885-2 Cordless Phone
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Register extra handsets
place handset in base, press menu, press vol button
select HS registration,
on handset press & hold # for 2seconds
Nov 23, 2007 | Uniden TRU8885-2 Cordless Phone
Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Jan 19, 2007 | Uniden TRU8885-2 Cordless Phone
Uniden Tru8885-2
The older Tru8885 phones will not work with the new base unit. My recommendation would be to ebay those and then buy new ones or find replacements for your new base on ebay also.
Jun 19, 2006 | Uniden TRU8885-2 Cordless Phone
Uniden TRU8885 Digital Answering Machine Logo
83 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
