Question about GE Spacemaker JVM1640SJ Microwave Oven
Replacing a GE Spacemaker Microwave Oven
I am picking up my replacement oven Monday and "old faithful" (25 years of service) has got to come out so that the new oven can go above the range. At first blush, it would seem that this is an easy installation, since the support bracket has already been installed and screwed into a stud. Everything should be ready for me!
I have downloaded the installation instructions and it all looks pretty straightforward. Apparently, the unit hangs on a bracket set against the kitchen wall and must be lifted slightly upwards so that the bracket disengages and the unit drops down. I understand that it is recommended that 2 people handle this job, and have lined up my brother-in-law to assist.
However, "old faithful" is installed beneath an existing cabinet. When I look at the floor of the cabinet, I can see the hole that was drilled so that the power cord can reach the outlet in the back wall of the cabinet ... and I cannot see any other screws and/or openings in the floor of the cabinet. The instructions clearly show that there should be 2 screws that align the oven to the bracket, but these are not there.
The exhaust fan is not vented and recirculates the air. The filter for this unit lays in a sheet metal assembly that also does not appear to be screwed to anything.
My question is how do I remove the old oven?!?
  • GE Master
  • 9,086 Answers
I don't mean any offense in my solution, and I urge you not to "kill the messenger" when you rate my solution, but I need to give you the facts as I see them.
When the oven failed to work right, it should have been taken out of service until it was properly repaired. Just jiggling the door would not qualify.
I couldn't imagine Sears having been found to have any liability for this, since the oven was known to be failing and it was used anyway, and it was apparently left running unattended, which every manufacturer warns against in their owner's manuals.
This post will be the public record of those facts.
It was almost certainly failing due to a bad door switch or door switch mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Maybe your insurance company will cover part of this damage, but as far as any liability goes, I'd say Sears is in the clear.
But I'm not an attorney, just for the record. I just work for them in liability cases in my capacity as an electronics expert witness.
If you do happen to file suit, I would be more than happy to give a statement on this, so feel free to contact me with the case numbers and court info.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 28, 2008
  • William Miller
    William Miller Dec 28, 2008
    * * * ATTENTION!!!! * * *
    Please ignore my solution here!
    Sorry, but I posted this to the wrong thread, it is NOT meant for your problem, so please do not rate it negatively.
    As to your problem, to clarify, if you have not downloaded the installation instructions for your old microwave, I would advise dong that here.
    Also,
    GE Customer Service is here, and they can tell you if the new model is a "drop-in" replacement for the old one (which saves a lot of trouble) and possibly give you tips on removing the old one.
My GE Spacemaker (JVM1331) will not turn off when door is shut. Have had to unplug unit. This unit is 15 years old.
one or more door swiches need replacing maybe be three in all but likely one is the cause not sure which one without testing with electrical meter
Oct 21, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl 1400 microwave stopped heating & there is an odor like melting plastic Can it be repaired. Is it worth it to repair. Unit is 8 years old.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgkjf
Dec 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacing old over-range microwave
Are the grease filters clean?
If you have a charcoal filter, make sure it's not clogged, too. These must be replaced, not cleaned.
In most cases, GE can recommend a "drop-in" replacement oven if you tell them the model number.
They should be able to tell you if larger ones will work in your current slot.
GE Customer Service is here.
Jun 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave is less than 2 years old and no longer heats. It comes on, but does not cook.
This odd GE last for ever.
Try replaceing the fuse. not everything runs off the same curcit , need hepl replacing contact me DFD
Apr 16, 2009 | GE Spacemaker JVM1540 Microwave Oven
GE Spacemaker Microwave display is flashing. Keypad is unresponsive. Boiled water for a long time under the unit. Person attempted to operate microwave. Loud boom and then this. There is a smell of...
Microwave is 16 years old. Replaced it. Service call was going to be half the cost of a new one with no assurance that problem could be fixed once it was diagnosed.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything
It's probably a defective magnetron.
This should have a one-year full parts and labor warranty, then another several years on the magnetron, typically 9 years.
A typical service call for this might run about $175 for the visit and repair labor, assuming the magnetron is still covered under warranty. Compare that to the cost of buying and installing a comparable oven.
Your owner's manual will tell you how long the magnetron warranty is.
You can save that home visit charge and get a diagnosis for about $25 or so by removing it from the wall and taking it to the nearest GE-authorized servicer.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Nov 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable not rotating
I fixed my own GE turntable by replacing the motor. You can purchase the part (#WB26X10135) directly from GE for $34.75 plus tax and shipping ($8.95) or from RepairClinic.com for $24.90 plus shipping ($6.46) and no sales tax except for delivery in Michigan.
The part is easy to install. Just print out this drawing to see where it goes (look for part 43) underneath the unit. Of course, be sure you unplug the oven first!
Hope this helps!
Aug 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1330BW Spacemaker Microwave Oven
REPLACE AND TAKE CARE NEXT TIME / SORRY
Oct 03, 2007 | Jenn-Air JMC7000 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
297 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
